lope
Old Dec 21, 2006 | 11:06 PM
Revelation Z28's Avatar
Default lope
how can you tell what cam, if any, you have if you have a slight lope in your exhaust? no vacuum leaks or missing. i think i have a little cam that came with the car from one of the owners. my heads look brand new under the valve covers, and my headgaskets are clean and new looking.
Old Dec 21, 2006 | 11:21 PM
porksoda's Avatar
Post a vid maybe someone can identify whether you have one or not. Otherwise the only way to check would be to pull it out and check the numbers that they grind into the end of the cam itself.
Old Dec 21, 2006 | 11:40 PM
goodrich969's Avatar
you cant really tell unless you post a video or something. hard to tell by the untrained ear. could be a off the selfer or a custom grind.
Old Dec 22, 2006 | 12:35 AM
WhyHelloOfficer's Avatar
Get it dynoed. That'll tell you if its cammed or not.
Old Dec 22, 2006 | 12:51 AM
yea, im waiting for the locals to get an group up for a dyno session. its pumping out more power and it pulls somewhat agressive for a stock LT1 with 148k on it.. i think it was molested in its lifetime.
Old Dec 22, 2006 | 01:00 AM
LSXNV's Avatar
it wont be exact, but you could pull the valve cover and set up a dial indicator on a rocker. measure the lift and watch your balancer to get and idea of duration. keeping in mind the crank spins twice as fast as the cam.
