Replacing LT1 barings
Old Dec 29, 2006 | 12:32 PM
Greenfire's Avatar
Default Replacing LT1 barings
About how long would you all imagine it would take to replace piston barings on a LT1? I know I've gotta drop the oil pan, among other things. I'll have plenty of help and I've been told it can take up to 5 hours to get the job done.
Thanks in advance.
Old Dec 29, 2006 | 01:21 PM
matt94z's Avatar
Do you mean piston rings, main bearings, or rod bearings? With any of those, your looking at a hella lot longer than 5 hours.... Your gonna need to pull the motor.....
Old Dec 29, 2006 | 01:59 PM
Greenfire's Avatar
rod bearings....yeah plan to pull the motor anyways, I was just looking to see if I could replace the bearings and still drive the car normally while I accumuliate funds to build the motor.
Old Dec 29, 2006 | 04:28 PM
The Big Show's Avatar
Why would ya just wanna replace the rod bearings?
Old Dec 29, 2006 | 05:22 PM
the_merv's Avatar
Veteran: Air Force
Yea.. you might as well build a new motor while you are there..
It's not that hard to do, but the bitch is getting it out of the Car, that's alot of work for just that. Why do you want to replace them?
Old Dec 29, 2006 | 05:46 PM
BizZzatch350's Avatar
Moderator
If they aint spun, leave em be
Old Dec 30, 2006 | 12:35 AM
rockcamaro97's Avatar
Just bring it to me S and well get ya fixed up lol. PM me bout ur problem, Maybe i can help ya come up with some options. Regardless, good luck!
Matt
Old Dec 30, 2006 | 11:08 AM
Greenfire's Avatar
Thanks Matt for the offer I'll pm you.
Well the idea was just to get the car back up and running by replacing the rod bearings since the #3 likes to make a rod knocking noise under a load and gets louder as the car returns to idle. Didn't figure it was a good idea to keep driving the car but could replace the rod barings and the valve springs while I'm at it?
It was just a thought so I could keep saving money and just drive it normally for a while. I've already got some parts for the motor, just need more $$$ like usual. Thanks for the advice.
The baring may not be spun but I don't think it would be long before it did. I've helped a friend pull his LT1 so I'm familiar with what a bitch it is to pull the motor. We have a cherry picker and a engine stand so that part is covered.
Old Dec 30, 2006 | 07:41 PM
Greenfire's Avatar
to the top
