which motor mounts is this k-member for?
Old Jan 1, 2007 | 06:06 PM
OneBad98Z's Avatar
Default which motor mounts is this k-member for?
i picked up a fourth gen roller and the car had this k-member, my question is what motor mounts is it designed for? im planning on puttting in a sbc.. it is a Pa racing k-member...
sorry about the quality of the pictures.
Thanks
Greg
Old Jan 1, 2007 | 07:22 PM
Z8'S's Avatar
Thats the same as mine, LT1
Old Jan 1, 2007 | 07:24 PM
Z8'S's Avatar
You also need to add the brace for your manual rack or you will pull the tube out of it.
Old Apr 6, 2009 | 04:50 PM
BIG_T's Avatar
what did u do to get it to bolt to lt1 motor mounts?
Old Apr 6, 2009 | 07:43 PM
pmbmax's Avatar
I have a lt1 k member in my car and a Little M block i built plates for the block then a place for each side of the k member put a 1 5/8 tubbing between the plates bloted a trants to it and leveled the car a squared it wherei wainted it the cut the pip and tacked easy to do with a empty block and just put the pan on it if you are goint o run headers i would check them befor you weld it out.
