Max Rpm
Old Jan 7, 2007 | 05:49 AM
95FbFormula's Avatar
Default Max Rpm
What is this max I could spin my motor to I am building a 355 forged pistons and rods stock crank fully balanced studed 2-bolt main. I wanted to turn around 6700 Rpm but if its to high for the stock crank I will probably turn it down a little
Old Jan 7, 2007 | 06:45 AM
the_merv's Avatar
Veteran: Air Force
Depends on your Cam..I am turning up to 6100RPM, then shifting. That's just how the powerband is.
Old Jan 7, 2007 | 07:29 AM
Speed Density's Avatar
hashtagBMW
Guy,
Id spend the money and 4 Bolt main the car.
Good Luck.
Tony.
Old Jan 7, 2007 | 09:05 AM
tbsimmons's Avatar
Depends on the cam and valve springs. I have the limiter in mine set to 6900 and it will hit it quick in the first 2 gears, then the 3rd is a little more controlable.
My stock motor saw over 6000 more than once, burnout boxes are fun.
Old Jan 7, 2007 | 12:39 PM
the_merv's Avatar
Veteran: Air Force
Yea, definately 4-bolt it with stuff turning that fast.
Old Jan 7, 2007 | 03:22 PM
Ari G's Avatar
the stock internals can spin to 7500,you need a good valvetrain but the pcm stops at 7250rpm
