No muffler?
Old Jan 8, 2007 | 09:27 PM
bene's Avatar
Trunion King
BTW, I was referring to Merv's exhaust... FYI.
Old Jan 8, 2007 | 09:52 PM
bmccrary's Avatar
Merv, sound clip please...
-bryan
Old Jan 8, 2007 | 09:56 PM
the_merv's Avatar
Veteran: Air Force
Here guys..
Thanks Bene.. you are about the only one that is here that has heard it in person. It does sound like a Big Block, alot of people say that. It got deeper with that Lid also..
This was the old motor also, new one sounds better..
Old Jan 8, 2007 | 10:05 PM
the_merv's Avatar
Veteran: Air Force
I was looking at Hyperzone's true-dual setup, mine sounds very, very close with that one dump. I might be able to run that setup on my Car, it looks like it will hang down just as much as mine does now.
Hey Bene, you have a Digital Video Camera, I can get some more vids of the Car if you do.
Old Jan 8, 2007 | 10:52 PM
hyperzone's Avatar
If you've filmed video of your car you know how it sounds different in various spots. The spot that I took that video there in the rear doesn't do justice to the amount of bass in it. I'll have to get some driveby videos here soone or later.
Old Jan 8, 2007 | 10:59 PM
the_merv's Avatar
Veteran: Air Force
Same with mine. I need a Camera though..
Mine sounds literally just about the same as yours with that single dump. I got that Cam in there opening up the Valves a little more, so it's deep..
Old Jan 9, 2007 | 06:53 PM
bmccrary's Avatar
Thanks merv... I love that sound man. If you could get some of inside the car that would be great. From everything I heard, drumps drone really bad, does yours?
-bryan
Old Jan 9, 2007 | 07:16 PM
the_merv's Avatar
Veteran: Air Force
Here is inside..
This is the old Engine again. Don't mind the crack in the Window
Old Jan 9, 2007 | 07:17 PM
the_merv's Avatar
Veteran: Air Force
-bryan
It's not that bad, but when I am on it, you can't hear **** but Motor with the Windows shut.
Old Jan 9, 2007 | 11:43 PM
Z 2 8's Avatar
Your car sounds good. So, what is exactly done to your car? I like your setup and how the car runs and sounds. It looks pretty fast.
Old Jan 10, 2007 | 03:31 AM
97Lt1TA's Avatar
as of now im running headers to y pipe out no muffler or resonator. people say sounds badass i agree but its louddd. only reason im running like that cuz my i pipe was the most retarded thing ever i mean i dont think it came stock on the car previous owner put it on i bet but it was 3 inch in some places then 2 1/2 inch in other and all different sizes. had it clamped to the y pipe and one day jsut came so i just took my whole cat back off. was going to get a texas speed rumbler but i dont know anymore that bullit muffler dumped sounds nice and is cheaper
Old Jan 10, 2007 | 06:08 AM
  #32
Ari G's Avatar
I have my exhaust system like The Merv but without a muffler and i have a Pacesetter LT headers
The Sound is Raw and Brutal but with a muffler it will be much more toned down and
Deep
Old Jan 10, 2007 | 07:13 AM
  #33
the_merv's Avatar
Veteran: Air Force
Both you guys have what I had for a little bit, and I got pulled over for begin too loud.
I put that Bullet on it, it got alot quieter, but it got alot deeper also. Get you a Bullet welded on, and you will love it.
Old Jan 10, 2007 | 07:20 AM
  #34
the_merv's Avatar
Veteran: Air Force
Here is a list..
4-BOLT MAIN LT1 CORVETTE BLOCK
LS1 AIR INTAKE WITH K&N AIR FILTER, GRANATELLI LID
DE-SCREENED MAF SENSOR
MSD BLASTER HEI COIL
PORT-MATCHED AND POLISHED THROTTLE BODY WITH AIR FOIL
PORTED INTAKE MANIFOLD TO 55mm PORTS
HEADS MILLED .006 INCH, RESULTING IN 52.7cc CHAMBERS
HEADS AND INTAKE MANIFOLD PORT-MATCHED TO INTAKE GASKETS
FELPRO 1074 COMPETITION HEAD GASKETS
EAGLE 5130 FORGED CONNECTING RODS
SPEED-PRO FORGED ALUMINUM PISTONS
ROTATING ASSEMBLEY COMPLETELY BALANCED
CLEVITE 77 ENGINE BEARINGS
MELLING OIL PUMP WITH SOLID INPUT SHAFT
LT4 EXTREME DUTY FULL ROLLER TIMING CHAIN SET
LT4 HOT CAM KIT:
-LT4 HOTCAM SPECS: 218/228 DURATION, .525/.525 LIFT, 112LSA
-1.6 RATIO LT4 FULL ROLLER ROCKERS
-LT4 VALVE SPRINGS
PACESETTER RACING COATED LONG TUBE HEADERS
CUSTOM COMPUTER FULL RACE TUNING:
-ADJUSTED FUEL/AIR RATIO
-RAISED REDLINE TO 6500RPM AND ELIMINATED SPEED GOVERNOR
-ADJUSTED TIMING AND SHIFT POINTS, SHIFTS AT 6100RPM
-PROGRAMMED IN ELECTRONIC SHIFT KIT
THROTTLE BODY BYPASS
OIL BREATHER BYPASS
RE-DESIGNED COOLANT CROSSOVER LINE
34% UNDERDRIVE CRANK PULLEY
POLY-URETHANE TRANSMISSION MOUNT
LS1 ALUMINUM DRIVE SHAFT
AUBURN PRO-SERIES POSI-TRACTION DIFFERENTIAL
MOTIVE BEARING AND SHIM KIT FOR REAR AXLE
3.73:1 GM DIFFERENTIAL GEARS
LS1 BIG BRAKE UPGRADE
ALL SMOG PUMP PARTS REMOVED
EGR REMOVED AND BLOCKED, TUNED OUT OF COMPUTER
AC SYSTEM COMPLETELY REMOVED, FIRE WALL BLOCKED OFF KEEPING HEAT
1LE AC DELETE PULLEY BOLTED IN PLACE
EIBACH PRO SPRING KIT
SLP STRUT TOWER BAR
BF GOODRICH KDW 285/40ZR17's on 17x9.5 Z06 WHEELS
Old Jan 10, 2007 | 07:58 AM
  #35
bmccrary's Avatar
Thanks Merv. Sounds great! What shift kit did you go with. the 1-2 shift seems to hit pretty hard but the 2-3 seems to just slide in more than most I have ridden in.
I have a small converter with my shift kit, and it hits hard... maybe I am just used to hearing mine.
Thanks again. Awsome car.
-bryan
Old Jan 10, 2007 | 08:10 AM
  #36
the_merv's Avatar
Veteran: Air Force
I actually have an Electronic one programmed into it. They boosted the Line Pressures up in the Computer so it will shift more firm. 1-2 shift will light the tires and throw the Car around, but you don't feel it at all, that's just how it works. 2-3 will chirp them, but not at much as the 1-2. Basically it's the same as any Shift Kit, but without all the Transmission work and the whiplash. That's fun in itself though..
Old Jan 12, 2007 | 10:15 AM
  #37
bmccrary's Avatar
Yea... the whiplash is fun... So with the electronic can you adjust the shift points and firmness easier?
And as for the 1-2 shift...yea its about bit me a time or two as well.. I don't have the motor to chip the 2-3 unless its wet. Put then again everybody has a racecar in the rain.
-bryan
Old Jan 12, 2007 | 12:12 PM
  #38
the_merv's Avatar
Veteran: Air Force
What my friend did with mine is take the program that the Trans has, and boost up the line pressures past a certian throttle percentage. If I am on it past 30% throttle, it will shift firm and take off. Under 30%, it will shift nice and easy, and cruise around.
Old Jan 12, 2007 | 09:52 PM
  #39
bmccrary's Avatar
Well that would certainly be nice sometimes... oh well.
I have learned to drive the car with the shift kit, if I do it right, the shift isn't as strong. However when cops pull up beside me, I try to judge it so I can get over the paint stipe before it shifts...
"officer, I swear I didnt mean to do that."
Old Jan 12, 2007 | 10:22 PM
  #40
the_merv's Avatar
Veteran: Air Force
I spun off of a paint stripe on a hill once in front of a Cop, that **** was funny. He looked at me and wanted to get me, but I guess figured out that it wasn't my fault. I like how it is tuned to do that. When I am cruising around, it's smooth. When I open it up, it takes off like a mother f#&ker, and powershifts the whole time. Who ever is with me is like holy ****..
