Lt-1 ?
Old Jan 8, 2007 | 12:25 PM
CMQuickcoupe's Avatar
Default Lt-1 ?
what is the difference in an lt-1 out of a caprice or impala vs camaro besides the heads being cast.Im also pretty sure the cam is different,what about intakes and everything else.Thanks
Old Jan 8, 2007 | 12:41 PM
METALBEAST's Avatar
The block is the same on the Impalla SS as the Camaro and Firebird. Some Caprices came with a 4.3L version of the LT1.
Old Jan 8, 2007 | 12:57 PM
Rowdy94's Avatar
Originally Posted by METALBEAST
The block is the same on the Impalla SS as the Camaro and Firebird as well as the cam and heads. Some Caprices came with a 4.3L version of the LT1.
False information. Do you really think a 3500lb sports car would get the same cam as a 4200 lb sedan? I think not.
Other than that...the aluminum heads we have. That may be it but I'm not sure.
Old Jan 8, 2007 | 02:21 PM
sdm1234's Avatar
this question has been answered NUMEROUS times on the board. try a search. also, try PMing 96capricemgr. he seems to know what's up. he chimes in almost every time about this.
Old Jan 8, 2007 | 02:29 PM
METALBEAST's Avatar
Sorry, typed it quick and added cam on accident..and FYI
https://ls1tech.com/forums/showthrea...52#post2682252
"** Thanks to Metalbeast for these specs "
Old Jan 8, 2007 | 05:13 PM
95FbFormula's Avatar
Here ya go try this
http://www.9c1.com/technical/LT1_rebuild/ar99928.htm
Old Jan 8, 2007 | 05:18 PM
Captainofiron's Avatar
Dont worry I'll pat you on the back.
Hahaha
Old Jan 8, 2007 | 06:53 PM
the_merv's Avatar
Veteran: Air Force
Lots of the major components are the same, Heads are different, the rest is suttle differences.
Old Jan 8, 2007 | 09:35 PM
METALBEAST's Avatar
Hahaha
Thank you...I thought I was gonna cry for a second
Old Jan 8, 2007 | 10:40 PM
Thanks for all the info METALBEAST AND 95FbFormula it was very helpfull,do either of you know if the intakes injectors an fuel rails are the same.Thanks in advance for any more info.
Old Jan 8, 2007 | 10:44 PM
the_merv's Avatar
Veteran: Air Force
Intake is the same, Fuel Injectors are the same, the Fuel Rails are different. The F-Bodies have the connects on the Drivers side.
Old Jan 9, 2007 | 02:26 AM
Charging TA's Avatar
Woah... too much false info here. Heads are iron on the Caprices/Impalas... (I wanted to include it in this thread incase someone searches and sees this thread and doesnt follow the links.)
Old Jan 9, 2007 | 06:49 AM
METALBEAST's Avatar
I deleted the **** out of my first post. Man I need some sleep or something
Old Jan 9, 2007 | 07:05 AM
the_merv's Avatar
Veteran: Air Force
The guy who first posted the question mentioned that..
Old Jan 9, 2007 | 06:41 PM
96capricemgr's Avatar
B-bodies have the fuel connections on the drivers side as well.
People love to beat up on iron heads and the "smaller cam". Reality is the irons outflow most of the aluminums and aluminum holds no maginc for making power. Yes it can allow more compression but the .4 higher compression the aluminum head LT1 got over it's iron head counterpart is hardly enough to be a big deal.
The cam in the b-body is not that different. The more I learn the more I realize that the difference in power ratings between the b-body and f-body had more to do with the b-body having grandpa quiet intake and exhaust as well as 87 octane tuning as opposed to the f-body 91 octane. Those who have made the mistake of asuming the f-body motor is much better than the b-body and swapped stock f-body motors into b-bodies have complained of slight lowend torque losses at least until they gave it a little stall or gear.
A well done bolton b-body is capable of around 300rwhp thru the automatic, far as I know that is ballpark what a well done bolton f-body does thru an auto too.
Old Jan 11, 2007 | 01:57 AM
Saw that but I only saw him mention they are cast, not the different material...
