cam for a 396!!!!
Old Jan 8, 2007 | 02:42 PM
slckstr96's Avatar
Default cam for a 396!!!!
i am in the process of building a 396 with 210 AFR LT4 ported and polished heads, port matched and polished LT4 intake, 11.7 compression, 3,500 stahl, 3.73 gears, and full bolt ons. planning on running 150-200 shot a little while later. i have been going crazy tying to figure out a cam. im pretty sure the duration should be around 240-250 and LSA should be 112-113. i do not want to go solid roller and the car is not a daily driver. the problem im having is what lift to go with. i called comp cams and they said around .580 with 1.6s. i also have 1.6s. but all the magazines that have LT1s in them, they run a little over .600. i dont know if this is over cammed or what. also the guy from comp told me that it needs to be an LT1 specific cam. i was told elsewhere that i can get a sbc cam through 1998. please help. sorry so long.
Old Jan 8, 2007 | 03:16 PM
LT1MAN's Avatar
simple, get a custom grind.
Old Jan 8, 2007 | 03:18 PM
Speed Density's Avatar
hashtagBMW
The car is not a DD and you 'dont' want to go SR? If your going to get a HR in the 240/250 you bet your *** your going to want lift over .580 if you want to make power.
And especialy with Nitrous, the SR is a much better setup to spray with, the bigger hits are a lot more managable with a Solid setup.
Tony.
