OBD2 KS compatible with a OBD1 Swap?
Old Jan 8, 2007 | 07:13 PM
Evaporate's Avatar
Default OBD2 KS compatible with a OBD1 Swap?
Just as the title states. I swapped from obd2 to obd1 and I'm close to starting up my new motor, is the obd2 knock sensor fine or do I have to buy a new sensor?
Thank you
Old Jan 8, 2007 | 10:35 PM
the_merv's Avatar
Veteran: Air Force
Should be the same thing, on the right low side of the Block..
Old Jan 9, 2007 | 09:46 AM
Ed Wright's Avatar
9-Second Club
Thank you
Just turn off DTC 43, your knock sensor will function normally. Anybody with Tunercat or LT1Edit tuning software can do that for you.
