whats the point of the air pump?
Old Jan 9, 2007 | 06:16 PM
zstangboi's Avatar
Default whats the point of the air pump?
i have read several threads, i have a 94 z28 and i hate the air pump, its in the way alot of the time, some say i can take it out no problem and some say it will throw codes, whats it for anyway?
Old Jan 9, 2007 | 06:31 PM
95FbFormula's Avatar
Since you are OBD1 you can take it out no prob shouldn't throw any codes. I have removed all mine doesn't really do anything just recycle exhaust gas.
Old Jan 9, 2007 | 06:58 PM
BizZzatch350's Avatar
Moderator
As log as the fuse stays good it wont throw codes
Old Jan 9, 2007 | 07:27 PM
borninatransam's Avatar
they say that its supposed to heat up the cats in order to prolong life and get better fuel mixture. i scraped mine a long time ago.
Old Jan 9, 2007 | 09:47 PM
zstangboi's Avatar
so since mine no longer has the cat, its dead weight anyway? just remove it, plug the hole in the intake, and do what with the dangling unplugged cord?
Old Jan 10, 2007 | 11:18 AM
PunkerPontiac's Avatar
correction guys, the air pump pumps extra air into the exhaust so the cat can burn hydrocarbons better. It doesn't heat up the cat cuz it just pumps air from the intake into the exhaust.
Old Jan 10, 2007 | 12:22 PM
MrDude_1's Avatar
catalytic converters require oxygen to operate.
however, if the engine is running ideally, it has consumed all of the oxygen already.
this of course, can be a slight problem.
when in closed loop operation, they get around this by "bouncing" between slightly rich and slightly lean... the switching O2 sensors you're used to seeing.... in this way, the cats get enough oxygen to operate.
but during open loop operation, the cats may or may not be getting enough oxygen... so under specific conditions, the PCM kicks on the air pump, blowing fresh, O2 rich air into the exhaust.
btw, in case you're wondering... at wide open throttle, there was no EPA emissions requirement, so even though its kicked out of closed loop, and probably running on the rich side, the air pump is not kicked on.
