how much boost will my t/a hold??
Old Jan 10, 2007 | 11:12 PM
ssrevenge's Avatar
Default how much boost will my t/a hold??
i have a 96 trans am ws6 with what i was told was an lt1 with lt4 cam and knock sensors? not really sure any way to find out? also how much boost will this car hold SAFELY?
Old Jan 10, 2007 | 11:18 PM
Speed Density's Avatar
hashtagBMW
I wouldnt push 7-8psi.
Tony.
Old Jan 10, 2007 | 11:19 PM
streetwarrior96's Avatar
well with 10:5:1 CR Not much probably be good for 7lbs boost at most
Old Jan 10, 2007 | 11:22 PM
the_merv's Avatar
Veteran: Air Force
Wouldn't be really worth it stock if you want to make it a Blower Motor. Get it to about 8.5-9.0 compression, then you will be good.
Old Jan 10, 2007 | 11:25 PM
ssrevenge's Avatar
thanks guys..would it be safe to spray juice on it? maybe 150 shot??
Old Jan 11, 2007 | 12:06 AM
onephatZ28's Avatar
No more than 7lb
Old Jan 11, 2007 | 12:10 AM
onephatZ28's Avatar
With out the boost, YES. With boost No.
I am running a 150 shot on my Z28 I have 117,000 miles on it. i love it
Old Jan 11, 2007 | 05:48 PM
LALT1's Avatar
That is interesting comment. Put a Vortech on a 95 M6 Z and went from 268RWHP to 398RWHP and blower was only change, that was even on teh same tune.
Old Jan 11, 2007 | 05:53 PM
ssrevenge's Avatar
thanks for all the help guys...i think i might go blower...the car has 122,000..so it would be alright huh??
Old Jan 11, 2007 | 08:03 PM
BizZzatch350's Avatar
Moderator
Your going to need a rebuild, only a matter of time. Might as well do it when your ready to put a new motor in. Drop the K and make it easier on your self for the install also.
Old Jan 11, 2007 | 08:06 PM
LALT1's Avatar
The 95 I spoke of was at 89,000 when blower went on and have put 56,000 more miles on it, very hard miles, no issues. Granted it would be safer to build it low compression, but if you have the blower or got a good deal on one, i owuld slap it on
Old Jan 11, 2007 | 08:09 PM
the_merv's Avatar
Veteran: Air Force
Good catch.. Let me re-phrase. It wouldn't get the most effect unless you got it down to 8.5-9.0 compression.
Old Jan 11, 2007 | 08:52 PM
goodrich969's Avatar
you have a lot of miles to be puttin a blower on it. Get a stock rebuild kit atleast then youd be good on the blower. But regardless your going to need it sooner or later...
Old Jan 12, 2007 | 06:38 PM
James Montigny's Avatar
Lots of guys running intercooled blower setups on stock bottom ends making gobs of power.
7 psi seems reasonable to me on a stock bottom end.
Old Jan 12, 2007 | 06:57 PM
Moderator
Yep and a whole lot of guys have also blown stock LT1 ring lands to peaces on boost. Hence the CZ28.com Forced Induction rebuild club.
Old Jan 12, 2007 | 07:03 PM
Old Jan 30, 2007 | 11:03 PM
Snake Eater's Avatar
Low boost will be fine. I just cant believe you bought an LT1, especialy after owning a LS1. We should run our rides for a little $. lol 4x4 Yukon XL vs. LT1. hehehe
Old Jan 31, 2007 | 12:05 AM
Valkyn's Avatar
What nitrous setup have you been running your 150 shot with?
/hijack
Old Jan 31, 2007 | 09:09 AM
Fire67's Avatar
With a completely stock motor, full exhaust, MSD box/coil/wires, NGK TR6 plugs, and 42# injectors I made 453rwhp 430ft-lbs on 10 psi from a D1sc... The motor survived 59K miles with that setup, being beat on every day as my DD and every Thursday night for Bradenton's T&T... When she finally lost compression, the motor had 96K miles on it.
You can make alot of power with boost, the stock compression will only hurt you because of the piston material. Otherwise there are alot of people making BIG #'s with 10:1 forced induction cars..
I personally had the new 383 built with 9:1 compression so I could go high with boost numbers and still run pump gas. Although with this D1sc maxed out, I may have to run at least a mix of race gas.
Bottom line, boost will eventually kill your motor. How long it will last is directly comparable to the weight of your right foot. People who spray there motors only get more life outta them because they're not reaping the rewards of more horsepower ALL the time. If you decide to play the forced induction game you need to know a few things:
1) Forced Induction is THE most expensive way to get power and maintain it.
2) Forced Induction is THE most rewarding when considering power gain only
3) Forced Induction will eventually destroy your motor, so be ready to build for boost when the time comes.
4) Forced Induction tends to introduce the driveline to much more power than it was designed to handle, get ready to do LOTS of upgrades in that department.
Old Jan 31, 2007 | 09:29 PM
ssrevenge's Avatar
i know i went to the lt1 side..but my ls1 was fun while it lasted..now i will try to blow up this lt1...might come out to g-town tomarrow bro..let me know when your gonna be home..i will come spank that yukon...lol..well probably not but its fun to think so
