HP difference 503 over LT4 HOT cam
Old Jan 19, 2007 | 08:01 PM
The stunningman's Avatar
Default HP difference 503 over LT4 HOT cam
I would like to know this.. I have searched and dyno info is scarce here and the search function is random at best.
Also does anyone have experience with the XFI lobes namely the 280 (07-467) whether it would be in the same category if advanced 3 degrees.
Old Jan 19, 2007 | 09:18 PM
eLTwerker's Avatar
I have the LT4 hotcam now(dyno 375rwhp). I'm putting in the 280XFI (2* advanced), but probably not for a few months. I'll let you know how it turns out if you're still interested.
Old Jan 20, 2007 | 07:04 AM
I have the HOT cam sitting on a shelf and found a good deal on either the 503 or the 280 xfi. I was just wondering whether it was worth the extra $$ to bump up to one of these grinds. I already have comp dual springs double roller and electric water pump.
Congrats 375 rwhp is amazing for a HOT cam. Let me know how it goes Thanks.
Old Jan 20, 2007 | 09:40 AM
Smokinlt1's Avatar
That's not with stock heads. Still agreat number though
Old Jan 20, 2007 | 10:37 AM
mybluez28echoes's Avatar
Default LT1 Removal
Wanted to ask you guys: What type of work would I AVOID or SAVE if I remove the engine from the Top instead of the Buttom?
Also, what parts on the engine should I remove while it's in to make the engine removal kinda easier if I want to remove it from the top?
I'm a first timer doing this here, so I will appreciate every advice.
Long live Camaros
Old Jan 20, 2007 | 04:09 PM
97LT1's Avatar
Long live Camaros
Do a search there is plenty info on that, along with guides. From what I understand some people prefer top some prefer bottom. Top is the way I will go.
Old Jan 21, 2007 | 10:27 AM
Smokinlt1's Avatar
I like going out the bottom
