help again
Old Jan 21, 2007 | 04:02 PM
TAdriven98's Avatar
Default help again
Well i got the whole delteq system wired up and everything back together, fired her up for the first time and she ran fine but there was a ton of light colored smoke in the engine bay right after I started it and it continued for about a minute when I turned it off. Is this normal? The only thing that didnt go as planned with the install was one old plug wire which i couldnt get to on the opti so I cut it as close as possible could it be rubbing on something causing the smoke because I tried to tuck it away. Maybe the new wires just have stuff on them or something. IDK
Old Jan 21, 2007 | 05:49 PM
Ralls's Avatar
It's probably your finger grease burning off on the headers.
Old Jan 21, 2007 | 06:24 PM
TAdriven98's Avatar
you think it would be that much, there was quite a bit I'll give it a start in a while and let it run.....
Old Jan 21, 2007 | 06:28 PM
Ralls's Avatar
Oh, I must of missed the word "ton." Then your right, that wouldn't cause enough smoke to be considered a ton. Did you ever try starting it again to see if it went away?
