new stroker setup, I have a few questions
Old Jan 21, 2007 | 09:49 PM
cgworth's Avatar
Default new stroker setup, I have a few questions
I picked up a forged 383 stroker kit and have a few questions before i install here are the specs and i was wondering if im going to have a problem with stock heads
forged dome 8cc dome pistsons with valve releifs
forged h beam rods
forged scat crank
i am currently using a gm 847 cam with 1.6 rockers on a stock head
will this setup work well together and could i use nitrous or what do i need to do to set this up for nitrous, any recomendations on anything elses to do while im rebuilding, I have a bbk 58mm TB with ported intake to match already, what are some other weak spoits i should give attention to while im building it,
Also i hace a t56 and would like to know of a good reliable clutch to use with this combo and what would be a fairly good tuning softwre to use..
thanks for any help you guys can offer
Old Jan 21, 2007 | 10:11 PM
streetwarrior96's Avatar
what compression ratio you going with. are you gonna get head work done???? Cause if ya don't your gonna give that motor breathing problems
Old Jan 22, 2007 | 08:15 AM
cgworth's Avatar
yes i was going to get the stock heads ported , would this be good enough? what else should i do
Old Jan 23, 2007 | 06:51 PM
cgworth's Avatar
ttt..
