Dry shot nitrous
Old Jan 22, 2007 | 09:41 AM
95FbFormula's Avatar
Default Dry shot nitrous
I bought a 10lb bottle off a friend of mine and I am wondering were can i get the rest of a kit, or build my own to run a 150 shot. I would like to make it button activated and not WOT, But i am new to nitrous so any advice would be great.
Old Jan 22, 2007 | 04:55 PM
Zralou's Avatar
Dynotune sells a 'dry' kit without bottle for under $300.
Sara Lou
Old Jan 22, 2007 | 05:41 PM
Taubr Unit's Avatar
cant run a dry kit on your car. Post this in the nitrous section and youll get all the info you need. I did the same dry kit on my car and got reemed by doing that. Your computer is not set up to read nitrous through the MAF. Post over there and youll get a lot more answers.
Old Jan 22, 2007 | 06:13 PM
ok thx.
Old Jan 24, 2007 | 08:49 AM
Stefan D.'s Avatar
You can run a dry kit. NOS sells a kit that does not utilize the MAF to read. It works off Fuel pressure and increase the pressure through the regulator. The nozzle goes in behind the MAF. Have run this on many LT-1s and on my old motors for years. http://www.holley.com/BrowseCatalogs...og=NOS&Page=19
Old Jan 24, 2007 | 04:08 PM
4thgenz's Avatar
i run a dry shot on mine!!
Old Jan 24, 2007 | 08:47 PM
FANTA-Z's Avatar
Yep you can run a dry kit without any issues. I started out with a dry kit on my 95 and it worked great. Basically all you need to do is hook up your button to a wot switch. This way it wont work unless your at wot and then it will engage your solenoid.
