rocker/spring question.
Old Jan 23, 2007 | 07:21 PM
Taubr Unit's Avatar
Default rocker/spring question.
Gonna do rockers in a few weeks. Im gonna do the Comp cams pro magnum 1.6's. I want to do beehive springs but dont know what ones to get. Also gonna do a cam later down the road w/ 550ish lift so i want springs to be able to handle that. What springs are you guys using?
Old Jan 23, 2007 | 10:10 PM
1slowZ28's Avatar
Got the same 1.6 Pro Magnums with these> http://store.summitracing.com/partde...6&autoview=sku
with a 550 lift you should be all right, there rated at 600.
Rest of part #'s
cca-795-16 retainer
cca-4705-16 locator
cca-613-16 locks
Old Jan 23, 2007 | 10:22 PM
Taubr Unit's Avatar
cool, thanks. Did you have to machine your head to fit the springs? I kinda want to go with beehive springs. I hear a lot of good things about them.
Old Jan 24, 2007 | 09:20 AM
1slowZ28's Avatar
I didn't have to on my Trick-Flow Heads, but not sure about the stock ones.
Old Jan 24, 2007 | 09:41 AM
gpss02's Avatar
i have the 918s(which i think are the beehives) on my 97ss along with the pro mags, and the comp cams retainers and locks as well.. i didn't get charged for any machine work so i don't think they had to be machined to work
Old Jan 24, 2007 | 12:55 PM
seawolf06's Avatar
918's work on stock Lt1 heads and are much lighter than dual springs.
Old Jan 24, 2007 | 01:13 PM
Taubr Unit's Avatar
it shows the 918's as ls1/2/7 springs. Will they work on lt1 heads also then??
Old Jan 24, 2007 | 01:24 PM
Taubr Unit's Avatar
Basically i want to build my valvetrain now for a cam later on. So beehive springs, ti retainers and what else?
Old Jan 24, 2007 | 01:28 PM
seawolf06's Avatar
Yes. They were designed for the LS1, but work perfectly on the LT1 heads. They are in fact, the most recommended springs for many of the most common LT1 cam packages.
http://advancedinduction.com/AiProductsLT1.html
http://eportworks.com/LT1LE2.htm
http://eportworks.com/LT1LE3.htm
Old Jan 24, 2007 | 01:36 PM
BlackScreaminMachine's Avatar
Internet Mechanic
yeap I used them on my cyl head s which are fo sale
Old Jan 24, 2007 | 02:37 PM
Taubr Unit's Avatar
thanks guys. Now i gotta figure what to do. What do you think about self-aligning rockers or not. I know the pro magnums for self-aligning is almost $100 more. Or get regular ones and throw on some guide plates and hardened pushrods. What u guys think on that??
Old Jan 24, 2007 | 03:06 PM
seawolf06's Avatar
Some say that the SA rockers won't work with the 918 springs, but I wouldn't know. I would only recommend NSA rockers with 7/16" studs and GMPP guideplates. This seems to be a more stable and stronger combination.
Old Jan 24, 2007 | 03:20 PM
Taubr Unit's Avatar
seawolf06, sent another PM, lol.
