LT1 ----> LT4
Old Jan 26, 2007 | 08:48 AM
Chevy_Ss's Avatar
Default LT1 ----> LT4
i'm planing to to shift LT4 heads and cam + intake in to 1996 impala with LT1 engine should i put LT4 PCM or tune my pcm
I'm not a pro , so help me guyz
Old Jan 26, 2007 | 09:39 AM
97blkz's Avatar
I have lt4 heads and intake your stock pcm will be fine. Tuned of course. When you say lt4 cam do you mean hot cam? If so get something better IMO. Thats's a wee bitty baby cam(best fat bastard voice used here).
Old Jan 26, 2007 | 02:38 PM
LT1MAN's Avatar
tune your pcm.
Old Jan 26, 2007 | 03:28 PM
Chevy_Ss's Avatar
thank u guyz
is LT1 cam as same as LT4 cam ??
and if it's the same if i wanna go for after market cam wt's good for daily use ?
Old Jan 26, 2007 | 03:35 PM
buffman's Avatar
if it's the stock lt4 cam that thing wouldnt be very happy in a Impala.
Old Jan 26, 2007 | 03:40 PM
Ls1Bait's Avatar
Yea there are many cams that are better for DD use. Best bet would be to talk to a sponsor on the boards.
Old Jan 26, 2007 | 03:51 PM
Chevy_Ss's Avatar
y? i'm not looking for a huge performance ?
Chevy_Ss's Avatar
like who ?
Old Jan 26, 2007 | 04:12 PM
buffman's Avatar
^^ Because the stock Lt4 cam isnt that much "bigger" than other stock LT1 cams. The LT4 Hot Cam is an aftermarket GM cam, that would still require at least 3.73s and a 3000+ stall in a 4000lb car to be a good highway runner.
Old Jan 26, 2007 | 06:41 PM
96capricemgr's Avatar
You would also be better served porting LT1 head than using the LT4s.
Things work a whole lot better if you research before you bought half the parts. I know it sounds harsh but everyone here has already made a ton of mistakes and we will try to help you. It is just harder for us to help when you already made some decisions that could have been made differently/better.
I am not saying the LT4 heads are bad, just that for the cost you could do MUCH better.
Roughly where are you, maybe we can point you at a local club or something? No better research than seeing a few already modified cars.
Old Jan 27, 2007 | 04:20 AM
Chevy_Ss's Avatar
that's y i'm asking coz i'm gonna keep the stock stall and stock rear end
Old Jan 27, 2007 | 04:22 AM
Chevy_Ss's Avatar
that's y i asked here . the proplem is that i'm from bahrain not from usa
Old Jan 27, 2007 | 10:21 AM
If keeping the stock stall especially do not bother with heads or cam.
Trust me that is a mistake I made. I did a mild cam before stall or gears. Well actually I had a 1650 stall as opposed to the stock 1400 stall but close enough to stock. Gained almost nothing from that cam swap till I later gave it a 2800 stall then gained basically everything you would expect from a cam and converter, later gave it 3.42s and pickedup a little more performance and it drove better.
Old Jan 27, 2007 | 03:36 PM
Chevy_Ss's Avatar
so better to change stock stall to 2800 stall and 3.42
Old Jan 27, 2007 | 10:07 PM
That would be a nice combo, ran 2800/3.42 for a while and it is a great combination of performance and drivability. Makes for a good launch and plenty of topend speed should you have enough road for such things.
Old Jan 28, 2007 | 03:23 AM
Chevy_Ss's Avatar
thanx guyz u helped me a lot ...
i'll keep u updated
Old Jan 28, 2007 | 01:22 PM
97blkz's Avatar
What's your goal and budget. If it's just a little pep we will reccomend one thing but it's to run 11's it's another.
Old Jan 28, 2007 | 02:40 PM
METAL MANIAC's Avatar
LT4 heads would not be that bad of a choice. They are capable of making 500
fwhp in stock form on a 350. Capable of a little more on a 383...MM
