What should it run?
Old Jan 26, 2007 | 11:05 PM
the_merv's Avatar
You are probably sitting mid 12's. I am estimating the same for mine, I have a couple more things in different areas, you have others as well.
Old Jan 27, 2007 | 11:20 AM
Bad Habit Bird's Avatar
Originally Posted by Ray@Nitrous Outlet
depending on the heads you can make 25-50 more HP with a different cam...I will cut you a smokin deal on my old custom grind.....
What are the specs on the cam you have? What kind of power did it make in your car? PM me the info on it if you want.
