Lt1 !evap?
Old Feb 2, 2007 | 06:02 PM
A-man930's Avatar
ditto
Old Jun 8, 2008 | 09:12 PM
C_Rules's Avatar
okay so where are the pics. im doing braided fuel lines and have all the parts. i'm just waiting on my engine so i can cut the line to the proper length. i'll be deleting the EVAP system completely but if there is a way to avoid a fume smell i'm down.
Old Oct 15, 2008 | 07:56 PM
Pretyflywiteguy's Avatar
back from the dead.. i'd like to see the pics also
Old Oct 16, 2008 | 06:34 AM
1SlowFormula's Avatar
I don't have pics but I also didn't go with braided lines, mine looks stock under the hood except there are only 2 tubes leading from the fender to the motor, and I also pulled the hardline from under the car and put a little filter (cheepy crank case filter off the shelf at the local parts store) on the end of the rubber fitting that attached to the hard line at the back, the filter isn't really needed, I just didn't want bugs or anything crawling into the tank from the open line...
Old Jan 27, 2009 | 07:29 PM
Black94Z28's Avatar
any updates with pics? looking to do this too
Old Jan 27, 2009 | 08:50 PM
multmigs's Avatar
Is there a functional point to this at all? or is it mostly just simplicity and looks???
Old Jan 28, 2009 | 11:42 AM
C_Rules's Avatar
probably simplicity and looks. you might as well do braided fuel lines as well if your doing the !evap.
Old Jan 28, 2009 | 12:52 PM
moderate Z28's Avatar
Im doing it because it makes the engine bay cleaner. That and it wasnt working right anyway.
Old Jan 28, 2009 | 02:18 PM
doaberetta's Avatar
Still would like to see some pics!
Old Jan 28, 2009 | 04:18 PM
C_Rules's Avatar
the evap line runs with the fuel lines. if you notice i don't have that ugly tube on the driver side which houses all the lines. evap deleted fuel lines were done with steel braided lines and re routed.
Old Jan 28, 2009 | 04:34 PM
Badazz 97 TA's Avatar
do you have any pictures of how your venting the gas tank?
Old Jan 28, 2009 | 07:12 PM
  #32
C_Rules's Avatar
i just plugged the hard line under the car. i didn't delete the evap canister in the back.
Old Jan 28, 2009 | 08:01 PM
  #33
Black94Z28's Avatar
if i do it, i want to remove everything i dont need. (car is on a diet) can i do this without buying anything?
Old Jan 28, 2009 | 08:14 PM
  #34
so as long as you leave the bigger rubber hose connected to the canister you can remove the other two small hoses? the bigger one is the gas tank vent correct?
Old Jan 28, 2009 | 08:36 PM
  #35
Formula350's Avatar
Originally Posted by Fire67
Im about to start posting pictures of my build, which happens to be coming to an end and should be racing within 2 weeks. My normal pc crashed and I dont have my cam software on this pc... As soon as my normal pc's fixed, I'll start posting pics. If any of you still need help then, pm me and I'll get you whatever pics I can.
Just to help you out. If you have Windows 2000, XP, Vista (or a variation of those), you don't need any camera software. Windows has a built in "Wizard" that takes care of it all. Camera software (along with Printer and/or Scanner) I find to just be added bulk to your system, and some of them add quite a few start-up programs which can slow start up and hurt system performance
Here's a question for you guys: Why not relocate the EVAP? Under the front bumper or (a bit more involved) back by the gas tank or elsewhere under the car. Quite a few newer vehicles have undercarriage EVAP systems, some even have ABS down there :S
Old Jan 28, 2009 | 09:17 PM
  #36
C_Rules's Avatar
you'd need to buy a vacuum plug for the tb. i needed one for the hard line too but if you're deleting that you won't need it. you'll also need something to cover the vent hose from the tank to prevent things from getting in there. also you'll throw a code once you remove the evap solenoid. you can program that out or just drive with the check engine light on.
Old Jan 28, 2009 | 09:24 PM
  #37
C_Rules's Avatar
are you talking about the lines under the car? if so I'm not sure since I never messed with the lines back there.
Old Feb 10, 2009 | 05:58 PM
  #38
Black94Z28's Avatar
Ok, i pulled the canister and got rid of the engine bay hoses. I have the three lines coming out that went INTO the canister. Since the canister is gone, do I just cap the three lines or should i still vent them somehow? If so, which ones do i cap and which ones do i vent? Thanks
Old Feb 10, 2009 | 06:09 PM
  #39
thats the same question i had. i assume you leave the bigger diameter hose alone(which i believe is the one from the gas tank) and can plug up the two smaller ones.
Old Feb 10, 2009 | 06:14 PM
  #40
Black94Z28's Avatar
Actually plug them or vent them somehow? or is the bigger diameter hose the vent, and i can just let that dangle there? Would i need a vented gas cap too?
