front clip conversion HELP!!
Old Feb 1, 2007 | 01:29 AM
pyronotic138's Avatar
Default front clip conversion HELP!!
i am doing the front clip conversion. can anyone tell me how the hell to pull the fenders off and put them on without scratching them and without taking the doors off. thanks
Old Feb 1, 2007 | 02:45 AM
transambandit's Avatar
if you unbolt all of the bolts you can see, inside the hood, under the bumper and inside the wheel well then you can pull it out a few inches and you can see where the 1 bolt is inside the fender, get your 10mm socket and go from inside. Hope you have some small hands/forearms cuz its tight. you should be able to do it without scratching it.
By Brett Foote | 2026-06-04 05:00:17
