LE3 questions..
Old Feb 7, 2007 | 08:37 PM
Cheek's Avatar
Default LE3 questions..
I got a 97 Z28 and im about to pull the engine out and send the heads off for the LE3 heads and cam. I know I need to upgrade my stall ,throttle body, and injectors(if yall know of any sites where I could get those things that would be very helpful).But do I need a bigger intake manifold,and a bigger mass air flow sensor for the bigger TB?
Old Feb 7, 2007 | 08:49 PM
streetwarrior96's Avatar
MAF is fine... send your intake to LE also if that is where your gonna go
Old Feb 7, 2007 | 09:02 PM
SStrokerAce's Avatar
Before you go jumping into the LE3 package.... whats the rest of the mods in your ride? Like what are you thinking about in terms of stall, max RPM, tires, gears etc...
Bret
Old Feb 7, 2007 | 09:10 PM
drumbo87's Avatar
my LE3 package is about 3 weeks out according to lloyd, if your using a stock shortblock with this package ive heard that there will be a problem with the valves and pistons...... just thought i would bring up the topics, hopefully bret or lloyd himself will chime in with a more detailed response. - jay
Old Feb 7, 2007 | 09:11 PM
Yeah stock bottom and the LE3 heads and cam are tight in terms of PtoV so I would defiantely check that . It's really ment to go on a 355, not a stock bottom end.
Bret
Old Feb 7, 2007 | 09:17 PM
James Montigny's Avatar
List of stuff I used and where I got it.
http://www.cardomain.com/ride/2297151/4
Brett is right though, if you're going to run a 350 with a stock bottom end,
go with the LE2. It's designed for that application.
Old Feb 8, 2007 | 02:47 PM
Cheek's Avatar
Thanks!
Old Feb 8, 2007 | 09:41 PM
97LT1's Avatar
Thanks!
Building a 383 LE3 in my 97, so Im reading up on a lot as well. You should still be cool with a MAF. I am thinking the MAF will make the ride more street friendly from what info im getting, compared to speed density.
