Hollowed out cat. Have a question.
Old Feb 12, 2007 | 09:12 PM
94lt1m6's Avatar
Default Hollowed out cat. Have a question.
My cat was clogged up, so i cut it off. Should i weld back in a three inch pipe back in place of the cat, or can i just put the hollowed out cat back in its place.
In other words with the cat opening up to like 6 inches wide be a problem or do i need it all to be 3 inches.
Old Feb 12, 2007 | 09:14 PM
hot black trans-am's Avatar
It be better with a pipe to avoid turbulance. My 95 made quite a bit more power and sounded bad *** once I dropped the cat off of it. Had a cat back kit on it too.
Old Feb 12, 2007 | 09:37 PM
94lt1m6's Avatar
turbulance?
Old Feb 12, 2007 | 09:42 PM
From what I've heard it makes more back pressure with a hollow cat due to the exhaust getting dumped into a larger area and sqeezed back into a pipe without being directed at all. People do it and it will work just to hollow it out, but you'd be better with a smooth straight pipe.
Old Feb 12, 2007 | 09:45 PM
94lt1m6's Avatar
oh i c. thanks.
