LT1 heads
Old Feb 13, 2007 | 02:04 PM
blkbird's Avatar
Default LT1 heads
How hard is it to install heads on an LT1 motor. A friend of mine blew her head gaskets and needs to get her car up and running again. Is there a write up anywhere on how to do this. I swapped the ones on my LS1 myself so hopefully it wont be much harder...
Old Feb 13, 2007 | 02:12 PM
Blackbirdws6's Avatar
wasn't all that bad honestly except there just is not a lot of room in the engine bay. I would say the hardest/annoying part of the job is making sure the intake manifold seats and seals properly. If you could handle ur LS1 this shouldn't be much more difficult.
-Brian
Old Feb 13, 2007 | 02:48 PM
seawolf06's Avatar
I wouldn't try it in the car, but it's been done. It's so easy to drop the whole motor.
As far as the intake installation, just use two dowel pins on one side to line it up with the heads.
