front sway bar removal
Old Feb 15, 2007 | 10:48 PM
97Lt1TA's Avatar
Default front sway bar removal
i was wondering if its true that removing the front sway bar can improve your traction. i know people do it for the weigh reduction but does it help with traction
Old Feb 15, 2007 | 10:53 PM
b00ya4u2's Avatar
it helps with weight transfer which can help lower 60ft times.
Old Feb 15, 2007 | 11:27 PM
the_merv's Avatar
Veteran: Air Force
I would still keep it for handling, it helps out alot.
Old Feb 16, 2007 | 10:10 AM
ABA383's Avatar
I ran 1.55 60's with it and w/o it...I just left it out to do some more testing, but if I don't improve I may put it back in...It does save a few pounds off of the nose...
--Alan
Old Feb 16, 2007 | 11:46 AM
Ralls's Avatar
It really only starts to make a difference when you have better shocks and actually done stuff to the car. It's going to allow a little more travel but the stock shocks are still going to hold down your tires.
Unless you keep it off for good, it is completely retarded to take it off for the track, then put it on for the street.
