x pipe importance
Old Feb 19, 2007 | 08:25 PM
Revelation Z28's Avatar
what setup is it that you have no X or H pipe, just straight out with bullets?
Old Feb 19, 2007 | 08:28 PM
camar0corey's Avatar
Well I had dumped duals with no x pipe or h pipe on my 83 z28, that had a 350 with world heads and a mild cam. 3" piping with Holley afterburner mufflers. I can live with the noise, strokinit383's setup is giving me hope.
Old Feb 19, 2007 | 09:01 PM
Quick96ss's Avatar
so No to x pipe or h pipe with bullet dumps for a street/strip car???? i will only drive the car on weekends. Should i just leave my 2OTL cat back???
Old Feb 19, 2007 | 10:29 PM
slick1851's Avatar
True Daul 3inch exhaust is on tomarrow!!!!!!!!!!!!! WOOT WOOT
Im running Dyno Max bullets! Its going to sound so nice, and im going to pick up a nice amount of power!
Old Feb 19, 2007 | 10:30 PM
Quick96ss's Avatar
are you running a h pipe or an x pipe??
Old Feb 20, 2007 | 05:46 AM
12345678910's Avatar
so how much hp would you gain switching from a ory with a cut-out to an x-pipe with bullets
Old Feb 20, 2007 | 11:06 AM
TurboZ28's Avatar
For a while I had bullets right after the header collectors as a temporary fix while I saved some cash. Don't do it. Exhasut fumes are harsh, they bump the floor pan occaisonally. It's just not a nice setup.
Old Feb 20, 2007 | 02:37 PM
lt197formula's Avatar
Originally Posted by hyperzone
^^^ You paint a pretty grim picture there buddy... Do you also have a cam? That could make a difference. I'm running almost a stock cam and its only crazy loud when I floor it. Although I have sound deadening/proofing material in there for the stereo so that probably helps a bit. I have no problems conversing or listening to music at a decent volume. Now, if I mash the gas and let the RPM climb high, then yeah, it gets ridiculous loud. "I'm" typically not holding a conversation or paying much attention to the radio in those situations.
Yes I have a h/c setup now but I got the exhaust before when I still had a completely stock motor. With longtubes, 3 inch x pipe, and bullets dumped before the axle it was still very loud. And the original poster was talking about running dumped bullets off of his longtubes which will easily be louder than what I had. I have also ran my exhaust dumped for a little while on my current engine setup when I was having my 12 bolt installed and it sounded like the world was ending. I reconnected the over the axle sections after a few drives because it was just way to much for a daily driver.
Old Feb 20, 2007 | 03:39 PM
foggedz's Avatar
I have had an 3in X pipe into bullets on my car for 2 years. It was loud, but I never got any loud exhaust tickets with that setup. Before I went to the X pipe I had a standard y pipe/ full 3in setup with a cutout right before the rearend, and I got 3 loud exhaust tickets with that setup.
For this year im keeping the x-pipe, and swaping out the bullets for 2 borla XR1 mufflers. I had a borla on my old 3in setup, and liked it alot. Two of them after an x-pipe should sound even better.
Old Feb 20, 2007 | 03:49 PM
Quick96ss's Avatar
do you have any sound clips of the borla??? Would they be better then the bullets??
Old Feb 20, 2007 | 04:50 PM
foggedz's Avatar
The bullets dont really change the tone of the exhaust. Just quite it down slightly. The borla XR1 is an actuall muffler. They should quite the car down a good amount over the bullets, plus give the exhaust a better tone. I dont have any sound clips from my car.
Old Feb 20, 2007 | 09:15 PM
  #32
I'm going to try to go with the H pipe route, and not dump them off the headers any more.
Old Feb 20, 2007 | 10:28 PM
  #33
BlazerINtheWork's Avatar
bahhh i still torn between the x and h pipe, choices choices.
think i am going to go with a spintech muffler tho. suppose to be quite at low rpms but still get loud at higher rpms, and flow well.
Old Feb 20, 2007 | 10:41 PM
  #34
foggedz's Avatar
I would do some searching on the spintech mufflers. I have seen some high hp cars loose 20+hp with spintech mufflers. They also have a very unusual sound. Very raspy.
For those that read the previous link about X and H pipes, you have to remember they were talking about mustangs. Mustangs have a different firing order than the LT1 and the exhaust tone is going to be totaly different. I think there is a reason that H pipes are not as popular on LT1 and SBC engines, but I have never personaly head an H pipe on an LT1 or SBC.
Old Feb 20, 2007 | 11:28 PM
  #35
wow, any idea what spintech muffler it was? glad i heard this now
great, back to square one. defintly not going with flow "master"
Old Feb 22, 2007 | 07:56 PM
  #36
redneck01's Avatar
i ran cats, y-pipe and loudmouth..then dual bullets dumped at the axle..loud with a 383 and 503. now i have edelbrock rpm mufflers, and its deep and loud, but too quiet for me. im putting in cutouts next week...oh and i run STRAIGHT pipes with no x or h off longtubes. its niicee
Old Feb 22, 2007 | 07:59 PM
  #37
slick1851's Avatar
I really find that hard to belive about spin tech loosing that much power......
Wich muffler were they using?
Old Feb 22, 2007 | 09:00 PM
  #38
foggedz's Avatar
Not sure, but it was on a 4in muflex system. I believe I read it on a thread on c..z28. com. But, I have heard 2 different cars with spintech muflers in person. And, like I previously said I didnt like the sound. Too raspy
Old Feb 22, 2007 | 09:09 PM
  #39
Out1aw's Avatar
From what I understand though, the power gains between a ORY and LT setup compared to a true dual setup isn't incredibly signifigant until you make enough power to need that kind of an exhaust system...
Old Feb 22, 2007 | 10:18 PM
  #40
slick1851's Avatar
See now thats different, a 4inch Y pipe catback setup is eqaul to 2.5 true dauls
Somthing like that, I cant rember and I think one of the 3 muffler choices one if more restrictive....
Search around for more info, my memory is ok......
