Oil Pressure Sensor Boot
Old Feb 18, 2007 | 08:16 PM
1QWKT/A's Avatar
Default Oil Pressure Sensor Boot
Having problems with this. I can't get it on because of my headers. Anyone else run into this? Thinking about maybe wrapping the sensor and wire with heat tape instead.
Old Feb 23, 2007 | 12:59 PM
1QWKT/A's Avatar
No one else has ran into this problem with Pacesetter longtubes?
Old Feb 23, 2007 | 03:30 PM
lt1formula2000's Avatar
Are you talking about the stock oil pressure sensor. If so I don't see how it could be a problem since it's monuted on the back of the block
Old Feb 23, 2007 | 03:32 PM
Speed Density's Avatar
hashtagBMW
Not if he has a 93.
Get some brass fittings and make a 90* angle and point the whole unit itself forward. And the put the boot on.
Works like a charm Ive done it on 2 cars and had no problems.
Tony.
Old Feb 23, 2007 | 06:33 PM
RymerC's Avatar
You could take the boot off and run it that way, I did for 2 years. I would reccommend changing the location to the back of the block, right behind the intake manifold. There's already a place there, you just need teh 90* fitting and maybe one more to screw your sensor in. This is how 94+ cars are I believe.
