B-Body guys in here
Old Feb 20, 2007 | 10:48 AM
Honda Hunter's Avatar
Default B-Body guys in here
Have a couple of questions.
Is the 88/89 4 door Caprice a B-body also?
Where do you get your suspension mods from?
What suspension mods do you reccomend?
Thanks
Old Feb 20, 2007 | 02:16 PM
buffman's Avatar
Yes that's a Boxy B-body
IIRC the same mods us 91 and newer cars use can be used on the boxies. Such as springs, and shocks. I believe even the control arms are the same..
Old Feb 20, 2007 | 02:26 PM
Cool. What are some good forums for more suspension info and where can I get them? This thing floats like a friggin boat.
Old Feb 20, 2007 | 02:30 PM
buffman's Avatar
you can go to www.impalassforum.com Even though you don't have an 94-96 LT1 the guys there are usually friendly
Old Feb 20, 2007 | 02:31 PM
Cool. Thanks.
Old Feb 20, 2007 | 06:45 PM
96capricemgr's Avatar
Just consider you will need different spring rates and swaybar stiffnesses as your car is several hundred pounds lighter than the 91-96 cars. The chassis was almost unchanged 78-96 and is fairly similar going back farther.
