New H/C LT1 DYNO numbers!!
If you're not making your peak by 6500 I'd say your cam is a bit too big...If you're going to peak at 6800plus you'll need more rear gear to get you close that rpm by them end of the track...And you really want a converter to stall 500-700 rpm below the torque peak of the motor. Plus as others have said you dont want to see 6800 rpm very often with a stock bottom end...FWIW Eric Bradby and Joe Overton told me once that with LT1 castings anything over .570" lift is a waste...Your heads flow way better than my E.B. Ported LT1s, but as someone said earlier we are not racing flow benches...
I wouldn't run it too much more with that 14.5:1 A/F, that's pretty lean...Good luck with evrything...Get the tune right and try the track and look at your mph...That will tell you whats going on...ET is a function of traction, so don't be too concerned with that part yet...
--Alan
--Alan
Originally Posted by Hark_Z
What are your results? You have very similar mods..
now i have a as&m 1 3/4 mids, magnaflow catback, bigger cam, msd opti, and mickey thompson et streets. ran the car 4 times it still hit the rev limiter even though i swore i fixed that problem and i ran a 13.2, 13.8, 13.4, and a 13.8 at 104. so go figure the car wouldve probably ran 13.2 with just the mickeys and the old setup anyway. this piece of **** should be in te 12s but refuses. dollar for dollar i probably have the highest costing shittiest running LT1 out there. not to mention it will not cut a 60 under 2 seconds even if it had a ****** rocket pushing it.
sorry folks just had to vent some frustration.
Originally Posted by Ari G
have you compression tested the engine?
i need to know what a bad driver is. what is considered a bad driver in an automatic? for a manual the margin for error is greater but can someone break down bad driving in an auto. maybe i can stop blaming the car if i fit the description of a bad driver.
--Alan
--Alan
Thanks for the info Alan, I think you hit a lot of this right on. I am more than ready for a more ideal cam, but the shop is working hard on getting mine to run right and see what they can get out of it so Im waiting to see the final results and run the car before I stress too much about the #'s. I already have a few good size comp cams in mind though..
Originally Posted by speed_demon24
The cam isn't the problem for it not putting out the #'s, you need to find out whats wrong before you go changing out the #'s. And if your tuner is still working on trying to tune it, I would try to find a new tuner ASAP, it doesn't take that long to tune a car....
