LT4 rockers on stock springs
from Crane 404psi rating, 1.175 coil bind point the part number: 96877-16
or from crane 391psi rating 1.085 coil bind the partnumber: 99893-16
from comp cams 403psi rating, 1.195 partnumber: 978-16
just in case you want to look for your self other brands, remember you need a outside diameter spring of 1.460 and an installed hieght 1.85
