changed to 2.0 valves,now have to replace springs
DOes any one offer a 2.0 1.56 combo that is shorter then stock?
IF changing the springs is the only option then what spring part number will it take that is taller tehn the 918?
Something aint right here, a lot of something and in the end I think you are screwed because you used an incompetent shop.
Some combination of seats, locks, shims should make the 918s usable, if not they used MUCH longer valves or really messed up the heads like to the point where they should replace them.
Jim
Taubr Unit: Yes, I had the +.050" locks to give an extra .050" to the install height.
It's the thick comp locators that decrease the install height, hence the taller locks.
Did he mention if you could do shorter valves at all?
If the shop is really that good they should be telling you what they need to do to make things work not looking to get info from you.
Also understand we don't race flowbenches and that for a flowbench head the valvjob can be manipulated to provide massive flow gains but will not actually work on the motor because they wont last.
Honestly the best thing that can be happening here is that you missunderstood them somehow.
I have never heard of sinking a valve that far and what I wanted to know on here was there any one else that had to do this to fit a 2.0 int valve.
I am not trying and dont want any one to be discredited as this really is a fine *** machine shop. TOp quality work comes from this shop. I have not actually talked to THe guy, a freind that built the engine is the one talking to him and there is no misunderstanding, it is .200 sunk in.
I was just wondering would it be worth it to get new seats put in for bigger valves to where the 2.0 's would not have to be sunk in.
2.00 should have worked just fine on stock seats.
