Is my fuel pump bad?
1. Turn on the key and listen for pump @ the rear of the car
2. Disconnect the fuel line from the filter or fuel rail and turn the key on (see if fuel comes out)
If all that checks out and you get gas everywhere, ur good. To test if your fuel is getting there, try cranking and spraying carb cleaner in the Throttle Body, if it starts faster or starts then ur injectors could be dirty or faulty fuel rail, try to change fuel filter too.
My pump was strange.... had a full 12 volts to it, it would prime when the key was turnd on but it would only hold 12 pounds of pressure, and then drop to zero right after it quit priming.
When i could get it to start, it wouldnt raise anymore than 12 pounds. 12 month warranty, 13 months old... go figure!!
good luck though!
