224/236 .538/.542 114 lsa???
Old Mar 14, 2007 | 10:20 AM
wkniffin98ss's Avatar
Default What numbers should I be getting?
I just put a cam in my girlfriends car and I dont think that it put down as much as it should. I also put in some jet hot ceramic coated long tubes,3" true dual exhaust with flo pro twisters, it already had some lt4 roller rockers, and a 2000 stall. What would you guys think are good hp and tq numbers for this set up. The cam is a 224/236 .538/.542 on a 114 lsa. The car is a 96 A4.
Old Mar 14, 2007 | 10:59 AM
Come on somebody has to have some kind of opinion.
Old Mar 14, 2007 | 11:12 AM
plaf713's Avatar
330/350 hp/tq, just taking a stab
Old Mar 14, 2007 | 11:20 AM
That is what I was thinking too but the damn thing only made 300 hp and 310tq. The guys who tuned it were saying that it was pretty good, but I think it should have done a lot better.
Old Mar 14, 2007 | 11:30 AM
lilbuddy1587's Avatar
Goddamn OPTI
Old Mar 14, 2007 | 11:37 AM
Originally Posted by lilbuddy1587
Goddamn OPTI
Old Mar 14, 2007 | 11:50 AM
streetwarrior96's Avatar
would have been a nice cam if it wernt on a 114 LSA. Good for 330 to 350 if ur lucky
Old Mar 14, 2007 | 11:58 AM
The cam is surprisingly choppy, I didnt think it was going to sound the way that it does, I could only imagine it on a 112 or a 110.
Old Mar 14, 2007 | 01:51 PM
plaf713's Avatar
it should make more power though, good thing its in your girlfriends car and not your own
Old Mar 14, 2007 | 02:05 PM
Ya, I really cant have her beating me anyway. I honestly think that I am having a tuning issue, because she said before the tune the car felt really fast, and when we got it back yesterday from the tuner it really didnt feel like it had any *****. It also doesnt shift 2-3 when you get on it. I dont think they have enough pressure in the lines, causing the clutches to slip. Thus making the dyno results incorrect. Thoughts??
Old Mar 14, 2007 | 02:53 PM
LT14LIFE JT's Avatar
the 2-3 shift is controlled by the PCM. They fugged that up if it won't shift. Dyno #s are low for cam only as bolt ons are making more, but another dyno tune may cure your problem. Check your A/F ratio and make sure your O2 sensors are working. You could have an internal problem but it doesn't seem to be that.
Old Mar 14, 2007 | 04:38 PM
Ya we are going to drop it off tonight, the people who tuned it are kinda leaning towards a tranny problem and he really doesnt really want to put it back on the dyno. He better re-dyno it but I have a feeling he is going to try to say that it is the tranny.
Old Mar 14, 2007 | 05:34 PM
C_Rules's Avatar
I dynoed shitty and ran shitty at the track with heads and cam. I got a new cam opti and exhaust after about a year and im getting a re tune this weekend by cartek. hopefully those guys can help me out. my first dyno tune by someone else was unimpressive.
Old Mar 14, 2007 | 05:57 PM
When we did the cam swap we pulled the engine changed every seal on the motor cleaned the heads cleaned the intake manifold cleaned the entire motor changed out anything that was bad, worn, including the opti spark. The motor was like brand new when we put it back in.
Old Mar 14, 2007 | 06:04 PM
sam95transam's Avatar
That is a bit suprising. I recently had my car dynoed and it running on stock tune. I have unported heads and the cam is cc305 .544/.544 220/230 w/ 1.6 promag rockers and 112lsa. on the stock tune it put down 304 hp and 345 tq. it also has 2000 stall like your gf's. Other mods include full intake, pacesetter longtubes and corsa cat-back, stock gears
Old Mar 14, 2007 | 08:28 PM
C_Rules's Avatar
with my old setup 355LT1 210/224 112 lsa cam 1.6 rrs ported polished heads shorties and a flowmaster i did only 309 after the tuning was over. goes to show u how some LT1s are turds and others are not.
Old Mar 15, 2007 | 08:32 AM
Well I dropped it off at the shop last night, and they just called and told me that it was the tranny. I think they blew the clutches out when they were tuning it. Its BS the car was fine when it went in there and now its fucked. When we pulled the transmission the casing was cracked so we replaced the casing and when the guy did that he said the clutches were on their last stretch so he replaced them with some good used clutches, and now they are fucked. Its Bullshit, I hate mechanics seems like they cant ever get anything right, and they just screw stuff up. I should have just gotten a mail order tune and saved $200 and the tranny. If I am being a little girl about this let me know but I do know that the car was fine before the tuner got a hold of it.
