LT1 head gasket
Old Mar 14, 2007 | 05:14 PM
HoLLo's Avatar
Default LT1 head gasket
I'm lookin at an LT1 with a blown head gasket.. what are the chances of anything else being messed up? After the gasket was blown it was shut off and only driven like a 1/4mi after. What kind of work would need to be done? what's a rough price and labor? i'm totally new to V8 labor
Old Mar 14, 2007 | 06:17 PM
jd783's Avatar
if there was water in the oil they took out the bearings by driving it but if not you should be alright i think labor is about $1400 to have someone do it. just get some tools out and doit yourself it takes about 12hrs start to finish. make sure you get the heads checked
Old Mar 14, 2007 | 06:38 PM
grnmonster's Avatar
yea defanately make sure you get your heads pressure tested same thing happen to me and i ended up with a cracked head, and if they are still good why not get them ported?
Old Mar 15, 2007 | 12:17 AM
3pnt4maro's Avatar
1400 is what it cost me and they let old gasket material get in the oil causing a spun bearing..now i have a completely new engine....do it yourself
Old Mar 15, 2007 | 04:14 PM
lt1taracing's Avatar
chatt. im on SCF aswell. worst case would be hydraulic'd a rod(bent). if driven much it could have hurt the bearings aswell. what caused it to blow? theirs usually a reason (n2o, fan not working, airpocket in cooling system, bad waterpump). i can cut you a deal on the labor (alot better than what is quoted). also, when replacing the head gaskets use the 1074 felpro's(jegs or summit). the felpro's most local autoparts sale are junk.
Old Mar 15, 2007 | 09:39 PM
HoLLo's Avatar
Yeah Matt is selling it.. its puffing out some white smoke after about a minute of idling.. what kinda prices can you get me? PM if needed
Old Mar 16, 2007 | 03:06 PM
which matt? also, check p.m.s
