sea foam
There is a thread with every question about seafoam you could think of in it.
But yeah unless you poured it in with the engine off then I don't see how you created a problem.
ps. your name stinks. lol
The car should start to idle high when you pull off the brake booster line. Not die.
Unless you are plugging the whole with your thumb or something.
Taking the line off will give you a massive leak, but it should still run. BTW, you need to give it gas when starting the car with the line off. If your car will not run, then I think you have a vacuum leak to begin with. Therefore, when you take off the brake booster line, it is WAY too low and cannot idle.
