stock hub on 3.75 crank
Old Mar 17, 2007 | 12:42 PM
lt1_2buku's Avatar
Default stock hub on 3.75 crank
can i use the stock hub on my 3.75 eagle crank?... i noticed that on the crank it has a "half moon" groove on the snout of the crank.... and my hub does not have anything that would lock into that? Also does anyone know the thread size and length of bolt i need for the crank and hub?
Old Mar 17, 2007 | 03:15 PM
foggedz's Avatar
The "half moon" your talking about is for a crank key to installed. Even the stock crank has this, but a key is not installed from the factory. Not sure on size of the stock bolt, but its def fine thread.
Old Mar 17, 2007 | 05:35 PM
lt1_2buku's Avatar
do i have to have the crank key in with the stock hub? and does anyone know the size and length or PN# of the bolt?
Old Mar 17, 2007 | 08:33 PM
fergymoto's Avatar
None of the stock hubs use a key. Put #1 at TDC and install the hub with the arrow pointing 12 o'clock.
Old Mar 18, 2007 | 10:35 AM
METAL MANIAC's Avatar
IMO..if you are putting together a new engine I would buy a keyed hub from Thunder Racing and put a key in the crank..My thought is a used hub with out the keyway may not hold like it should....MM
Old Mar 19, 2007 | 08:33 AM
SpeedDensityZ's Avatar
The only problem with that is they are backordered and no one knows when they will have any. I called last week and they have been backordered from November and will not know when they'll have a shipment come in.
