MSD Opti Write Up and Comparison
So here is a write up and a comparison to the OEM GM unit.
MSD Pros and Cons
Pros: Adjustable timing, better one piece housing design, less likely to leak, no connectors to leak from. beefier opti sensor, beefier opti disk. extra cap bolt. MSD Cap is thicker and seems stronger. Rotor is beefier and indexed. Brass contacts all around.
Cons: Cost, O-ring gasket is a PAIN! to install.
Write Up:
The MSD unit is made from one piece of aluminum, therefore allowing for less possible leak points opposed to the two piece GM Cap. Also since the harness is sealed from the inside and has no connector hole it again allows for less possible leak points. The MSD unit has adjustable timing, but MSD techs told me that you needed to fab up a timing reference like on the older SBC before you attempt to adjust the timing. The MSD Cap is alot thicker and does not have the recesses that the GM unit has, therefore it would be stronger and resist cracking more. The MSD cap has all brass contacts which means better conduction than that of the GM mystery steel contacts.
Here are the comparison pics:
any word on the reliability of these over stockers?
my opti junked out the High-res circuit on thursday (makes the 5th one in a year) I'll give the parts-store brand one more chance, then I'm going with an MSD, I can't take this crap any more!
One MAJOR con that should be noted is this should not be used unless you fabricate a timing pointer and switch to a keyed hub and marked damper so you can confirm adjustment of the optical pickup. Otherwise you are just hoping timing is right.
Its a good idea to take off the cap during installation though, just so you can make sure you got it pointing the right way. Also I couldnt get mine on with the cap on.
As far as reliability, I took it earlier to the car wash, and guess what I did, I washed the engine compartment and blasted it, and not even a hickup. It ran perfect. If I would have done that with the old one, I would have been stuck until it dried and then some.
Oh and 96capricemgr they come from MSD set to the OEM opti timing, which is two turns out on the adjuster screw. And I addressed the need for a external timing reference in my original post.
All i did was turned the adjuster back in untill is STARTED to seat, and then went 2 turns back out. Waalaa!!
I really wished MSD included a timing chain cover seal for the opti. I installed my opti, and it had a small oil leak coming from the rear seal. i took it back off and changed the seal. I did take the opti apart to see if any oil got in it and it was fairly clean. But i did notice that the rotor inside was rubbing the seperator plate. It had a red circle around it. But i deemed it ok, and put it back on.
I wouldve taken pictures but the digi cam was outa commission.
Honestly though i couldnt tell a difference with engine performance from 2 turns out to 5 turns out. But then again, my fuel pump is all F*ed up.
All in all though, it is a really nice piece that youll never really see!!
Time will tell how good these really are.
I will try to take photos when I do the swap... sometimes it's hard to stop when you're making progress.
The 8381 has a hose assembly for adding the vent feature. This should resist blowing out.
hey chree if you have the non vented Opti it might not hit on the balancer hub, the only thing that was making contact on the hub was my venting tube.
The only thing I have noticed about it was that it idles a little different when cold, but after that its great.
On the note of adjustable timing: wouldnt timing adjustment via the optical sensor also adjust injector timing as well as ignition timing? Also note that i do not have a crank sensor as i am a 94.
what the heck does the crank sensor do anyway? enable codes for opti res issues?
before msd i had major opti issues and no codes. was not even using cap and rotor. THANKS DELTEQ
You just slapped it on? did you make sure the oring was installed??
The timing adjustment is only meant, AFAIK, to correct timing when you advance or retard a cam. It is NOT meant to advance or retard ignition timing or "injector timing". Those are always controlled by the pcm and must be programmed.
*edited for coherence* lol
