i need help with shifter in 96 trans am
Old Mar 19, 2007 | 06:06 PM
onebadbird96's Avatar
Default i need help with shifter in 96 trans am
how do i get it out thanks,
jeremy
Old Mar 19, 2007 | 07:50 PM
the_merv's Avatar
Veteran: Air Force
M6, A4, what do you have...
Old Mar 19, 2007 | 08:22 PM
m6.........
Old Mar 19, 2007 | 09:43 PM
the_merv's Avatar
Veteran: Air Force
I don't have a M6.. isn't there 4 bolts ontop of the plate that is right on back of the Tranny, just about near the Tail Shaft...
Old Mar 19, 2007 | 10:10 PM
doug1105's Avatar
Unscrew the shift **** and take the pleather outer shifter boot off of the console.
Be careful not to break the plastic tabs that hold the pleather boot onto the console like I did.
Under that, there's a black rubber boot that's screwed to the floor that you have to take off to get to the shifter mount plate.
Once you get that off, it's 4 bolts and the shifter comes straight up and out.
