What do you think?
Old Mar 20, 2007 | 06:12 PM
Red97Z's Avatar
Default What do you think?
I drew this up as a sketch to how I'm going to wire up my rear mounted batt relocation kit. There's also a master disconnect switch in the rear. NHRA says that the alternator must be going to the batt even when the switch is in off position, but should I also run a wire to the positive power block from the alternator as well? What gauge wire should I run from the alternator?
Old Mar 23, 2007 | 12:01 PM
Red97Z's Avatar
back up
