what cam for nitrous???
Old Mar 25, 2007 | 08:26 AM
FIREHAWKONNOS's Avatar
Default what cam for nitrous???
looking at doing a very simple, almost stock rebuild then i want to put put to a 150 shot to the car just for when the odd race comes my way.what would be the best cam to go with i dont mind if i got to get the ecu redone,heads will have stock valves and just port matched same with the intake 58mm tb headers,and ram air the car is a 6spd and intend to put 373 gears thanks for any thoughts.
Old Mar 25, 2007 | 08:32 AM
my94blackz's Avatar
BIG on a 112
Old Mar 25, 2007 | 08:46 AM
well i was lokking at the hot cam kit just cause it comes with springs,rockers and clips
Old Mar 25, 2007 | 10:15 AM
96capricemgr's Avatar
If you think you can do mods like this without a MANDATORY retune you are not ready to do mods like this.
For a 150 shot do not even consider the nitrous when picking the cam, if it was a 250 shot then maybe but not for a 150. Just pick a cam you will like NA.
The HOT cam kit comes with inadequate springs so forget that supposed "benifit", and you owe it to yourself to open your eyes and see the vast array of choices available. The HOT cam was THE cam a DECADE ago today it is servicable I wouldn't give it a lot of credit beyond that though.
With a 6 speed consider 4.10s, .50 OD goes a long ways towards taming deep gears.
Old Mar 25, 2007 | 04:56 PM
with 4.10's wont i have to use 5th gear to finish the 1/4 my rev limiter is 6200 and i have 26.5 tall rear tires.
