Ford 9' or Moser 12 bolt?
Old Mar 28, 2007 | 04:44 PM
Lt1junkie's Avatar
Default Ford 9' or Moser 12 bolt?
Hey just finished up my motor and really need to get it to the ground, someway besides the 7.5 10 bolt i have now. Just wondering on anyones experiance and what would be my best choice. I beilieve i would have to get a new Driveshaft if i was to go with a ford 9 inch correct? thanks for your input
Old Mar 28, 2007 | 04:48 PM
LT1MAN's Avatar
Old Mar 28, 2007 | 05:19 PM
lt1taracing's Avatar
i run the same drive shaft i had with my stock rear, in the 9" i have now. you will need a "bastard joint". which mates the gm driveshaft to the ford rear. most autoparts stores carry them. if i had to do it over again, i would go with the 12 bolt or the strange s60. the 9" takes more power to turn than any of the others. it slowed my car down .15 in the 8th and around .25 in the 1/4. that doesnt seem like alot to some but it is to me.
Old Mar 28, 2007 | 05:28 PM
97M6Formula's Avatar
Although the nine inch does take more power to turn it also has less breakage. There are alot of fast cars running 12 bolts without any issues but it's alot less often that people have gear issues etc with a nine. I did a nine inch with the true trac posi and it was awesome. No noise and took alot of abuse and it was great on the street
Old Mar 28, 2007 | 05:33 PM
the_merv's Avatar
Veteran: Air Force
How much power do you think that 9" sucks up.. I know that they are tuff as hell.
Old Mar 28, 2007 | 05:41 PM
Hot94Z28's Avatar
I like the 9-inch. But what is the cost compared to a S-60? I heared they are stronger and lighter.
Old Mar 28, 2007 | 05:42 PM
just guessing, 20-25hp? maybe. i would think the strange s60 would be stronger than both. although it could possibly be heavier it would still take less power to turn.
Old Mar 28, 2007 | 05:43 PM
i think the s60 is around $2295.
Old Mar 28, 2007 | 05:46 PM
wonder if it could be bought for less with a spool instead of the trutrac?
Old Mar 28, 2007 | 06:02 PM
I bet the nine inch only takes an extra 15 hp but it also weighs probably 75-100lbs more than a 10 bolt(just guessing)
Old Mar 28, 2007 | 06:04 PM
Hot94Z28's Avatar
I have heard it takes less power to turn, But there heavy bastards.
Old Mar 28, 2007 | 07:58 PM
JasonShort's Avatar
Moderator
You could opt for the aluminum center section for the 9" which puts the weight of the 9" slightly less than the 12 bolt (from what I have seen).
Jason
Old Mar 28, 2007 | 08:06 PM
jmill96Z's Avatar
I would go with the 9". I love mine. Gearing can make up for the HP loss
Old Mar 28, 2007 | 08:22 PM
the aluminum center sec. is supposed to be 18lbs. lighter and they claim stronger than the factory modular unit. i'm not sure how much an alum. spool is lighter than a posi. unit but, its a few lbs.i'd guess 10lbs. i run an alum. spool myself with a stock cast iron center section. they make a lightened gear thats around 6lbs. lighter but, the highest gear ratio is 4.11 and goes to 5.+. none of them are indestructable, i've broke mine twice. maybe a lightened gear would make up for some of the lost power? i read an article where they dyno'd a car then removed and polished the ring and pinion, reinstalled it and picked up 4hp.
Old Mar 29, 2007 | 12:07 AM
the_merv's Avatar
Veteran: Air Force
That's alot of weight.. I can see maybe 40lbs max..
Old Mar 29, 2007 | 12:10 AM
DroppedM6Z's Avatar
I like my 9"
Old Mar 29, 2007 | 07:42 AM
JasonShort's Avatar
Moderator
I'll have to ask my buddy what options his 9" had......his 9" weighs the same as my 12 bolt and I know he has the aluminum center section. I remember being pretty suprised when I saw the scale with his 9" on it.
In any event, I would go with a 9" in a M6 car or a 12 bolt in an auto.
Jason
Old Mar 29, 2007 | 08:23 AM
-PEPE-'s Avatar
been there done that with a 12b, broke it launching @6200, has a 9" now, don't forsee any breakage especially with the parts we used.
