LT1 Fuel Pressure? Fuel Pump?
Key On: 8-10psi
Pump Key x10: Up to 30psi then drops to 0 in about 1/4 of a sec
Starting: Stays at about 30psi then it drops when key is off
I know the anti-bleed valve is bad on it but this is a stock fuel pump on a 388 stroker so I know its LEAN on WOT. The car started earlier and was stumbling really bad. T
The car will not start now and im getting plenty of spark. Anyone else agree?
I think its the fuel pump from the test, just wanna verify.
also the fuel filter is cheap insurance
I bought a walbro pump, and when i installed it, i noticed that the factory rubber hose connecting the pump to the hardline was split.
FYI...
I put an LT1 in an 86 chevy short wide truck. The fuel tank and sending unit is from an 87 model (factory equipped TBI). I NEVER thought about the fuel pressure difference between TBI (15 PSI)and MPI (40-50 PSI)...
In This picture you can see the "L" shaped split in the hose:
