New engine startup questions..need answers QUICK!
Old Mar 31, 2007 | 11:18 AM
ckyconan2003's Avatar
Default New engine startup questions..need answers QUICK!
What should i do about getting oil pressure? Dad says to push the pedal to thef loor to put the car in " flood start mode" so it doesnt fire the injectors. I dont have O2's right now or O2 sims. Would it be wise to even try and start the motor without these?
Old Mar 31, 2007 | 02:45 PM
freshmanit's Avatar
I've run without o2's before.. didn't do any harm. last time I had to prime it, I just disconnected the injectors and coil. Took a couple seconds, guaranteed no fuel or spark.
Old Mar 31, 2007 | 02:49 PM
Mighty Whitey's Avatar
even better, unplug the opti-spark connector (not the one ON the opti, but the one mid-way of the intake)
with out a doubt no fuel, no spark!
Old Mar 31, 2007 | 10:51 PM
chromeplated500's Avatar
When i did it on mine. I just pulled the two injector relays. Easy and effective.
Old Apr 1, 2007 | 01:08 PM
Turbo_6's Avatar
to do it properly, use a priming tool at the back of the block before bolting the intake down. Otherwise, you could try what other have recommended using the starter.
