383 Stroker LT1??
... so we found another block for him and he's doing a 383 stroker set up... .3o dished pistons, 6" rods and a balanced eagle crank... he's running it with a LT4 hot cam, stock un-ported heads, not sure if he'll have the money to get them done yet... long tubes, flowmaster super 40 and some 3.73's in the rear... besides that its going to stay pretty much stock except for maybe a TH350 swap in stead of the 4L60E... i'm not sure what to really expect from this cumbo but he had asked me if i think that he could keep up with me or take me after it's ready??? I have no idea since i have alot more bolt ons and head work.... what you guys think we can expect from this new motor, and will it take me???
... so we found another block for him and he's doing a 383 stroker set up... .3o dished pistons, 6" rods and a balanced eagle crank... he's running it with a LT4 hot cam, stock un-ported heads, not sure if he'll have the money to get them done yet... long tubes, flowmaster super 40 and some 3.73's in the rear... besides that its going to stay pretty much stock except for maybe a TH350 swap in stead of the 4L60E... i'm not sure what to really expect from this cumbo but he had asked me if i think that he could keep up with me or take me after it's ready??? I have no idea since i have alot more bolt ons and head work.... what you guys think we can expect from this new motor, and will it take me???Both my 383's were built using 6 inch rods. They offer less sidewall loading over the 5.7 inch and improve combustion as well.
Guess I used a lot of wrong parts.
Alright since nobody else cared to drop some tech on how this works i guess i'll get in educate mode to tell people how it works with rod length vs piston used....
Okay basically you can use a 5.7" rod, 5.85 rod, or a 6" rod with your 383. you might even be able to use longer/shorter combos but these are the norm. If you use a 5.7" rod your piston will have the area for the wristpin at a certain height in the piston. If you use a 6" rod the reason you can't use the same piston is because with that rod the piston would come out of the block .3 of an inch..... SOOOOO To make up the difference the 6" rod piston will have the wristpin moved up .3" higher in the piston than the 5.7" rod/piston.... get it..... you are increasing rod length but sacraficing wristpin depth down in the piston. This has multiple effects on the motor. Rod to piston ratio, sidewall loading, dwell time at TDC, friction in the bore (ie sidewall loads), etc..... Those are all good things. The bad thing is that sometimes you move the wristpin up in to the ring lands sacraficing piston strength.... it's a tradeoff..... but seeing as how the guys with crazy 383 builds are all mostly using 6" rods it's probably a good thing.....
hope this clears up some fuzzy ideas about this topic...
