ignition problem guessing game.
Old Apr 2, 2007 | 01:24 AM
InnocentZ28's Avatar
Default ignition problem guessing game.
I have a 97 lt1 camro and i have got a ingnition problem that i am confused on. When i put the key in and turn it to the power i get power from the battery and everything works, but i am not getting any power from my fuel pump, or my electric waterpump or anything when i try to start the car. i know it is not the fuel pump of my waterpump because my car did not do that when i put them on. But anyways i have noticed that the metal rod going from the key cylinder to the ignition switch is not moving with my key when i turn it. But also i have had this problem befor with my car not startin like this, but i did unplug the connection to my ignition switch and pugged it back in and the car fired up when i tried. So i am thinking that its my ignition switch but also i dont know if the rod has broke of fallen off at the key cylinder part, i have wiggled it and it still feels tight, but i am just not sure witch one it is. I tried moving that rod manually myself and turning the key and that did not work either. So the things i think it could possibly be are my ignition switch, broken rod, or a key cylinder. I hope that i made since with all of this and if anyone has question feel free to ask and let me know on some opinions.
Thanks, Josh
Old Apr 2, 2007 | 12:47 PM
slagger's Avatar
the rod should move when you turn the key.
I just put in a ignition yesturday I had the same probs you had but my rod was moving when I turned the key so I know it was the switch.
you will need a new key switch plus depends how many miles you have on your ride I would change the ignition switch, my gauges was bouncing around when I was driving and even trying to cut off and when youu turn the key to start some times it would hassate alittle then start...
switch was only total $30.
BUT a pain to put in you have to drop your whole steering colum
good luck.
Old Apr 3, 2007 | 12:27 AM
yea thanks man i went and bought a ignition mod today hoping that was it and dropped the column and now i just got on and read your post about what you did and i had guessed right lol. it was not fun pulling the column but this was my first time at doing this, and i did not realize there are two rods so i found the top rod and it moves so that made me more toward the switch. But i am only 17 so i am pretty proud of myself for doin this by myself.
