Heater Box/Core/Unit Questions. Pics Inside.
Denny, the headers are the stepped heddmans (Tony Shepherds, OutlawZ, Colts95ta run them) they are a big header and demand manual steering rack and !heater box.
Tony.
Well I got some 60 grit sandpaper, resin, fiberglass cloth and i started to glass it up.
Verdict= PITA x100000 but its working, im just afraid the 60 grit wasnt ruff enough...
Tony.
This is what I did, then again I have no intention on running AC. I am putting a few finishing touches on it still..
I used 1/16" Aluminum Plate, and sanded it with 100g so the paint would stick.
I should have put pants on
This **** is sticky as a mother trucker and its all over, i had to sit on the K member to apply the resin and hold the FG sheets, so the stuff got all over my hairy *** legs.
I put 2 sheets of fiberglass on and about 4 coats of resin, i will be sanding and bondo'n it up. I dont know if its totaly gona clear the headers (whenever i put em back on
Tony.
David
I use resin everyonce and a while, and yea its sticky alright
David
I am not that far along with my 'fabrication' skills yet.
Tony.
Is the whole riveting thing easy?
Shoot me a PM with your parts list for that project man, ill take pics of my fiberglass job and then post up to see what you guys think
Tony.
that gaping hole in your air box is on the cabin side of the heater core. meaning that on the other side (to the left) of the heater core, is the blower motor. that blower motor is supposed to blow air across either the Evaporator (in A/C mode) or the heater core (in heat mode) with the hole there, you cannot get "pressurized" so to speak, air up to your vents. it's all abou the path of least resistance. it's much easier for the air from the blower motor to escape through that hole, than it is to be piped up to the vents.
just fiber glass it up and you'll be fine. if you really wanna get ghetto with it, sheetmetal+ RTV sealer.
