Crane Cam
Old Apr 3, 2007 | 12:44 PM
asandman44's Avatar
Default Crane Cam
Hello All: I was discussing my rebuild with a mechanic buddy of mine and I was telling him I wanted to go with the Crane 227 "Baby" cam. He was looking over the specs and he had a question that I could not answer, so I figured I should post here and see what you guys think. The specs on that cam: lift on the intake is 210 but on the exhaust it is at 224. His question was why there was such a gap betwwen the sides, because, the lt1 burns pretty clean and most aftermarket cams are gapped closer? He suggested a Comp Cam he used before...
COMP Cams Xtreme Energy Camshafts
Intake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 224
as found on summit part number (502-8)
Should I be going with this one, has anyone used it, any info would be great?
Thanks, Aaron
Old Apr 3, 2007 | 03:26 PM
asandman44's Avatar
ttt...
Old Apr 3, 2007 | 04:26 PM
MEAN LT1's Avatar
Im confused, do you mean the duration?
Old Apr 3, 2007 | 05:00 PM
kyle97's Avatar
That cam was designed with the stock LT1 heads in mind, which have a very restrictive exhaust port relative to the intake port. The wide split helps balance this out and is one of the reasons the 227 is such a good performer with stock heads.
Old Apr 3, 2007 | 09:37 PM
dhdenney's Avatar
Same idea with the Comp 306, 230/244.
Old Apr 4, 2007 | 09:19 AM
asandman44's Avatar
thanks for the info....
Old Apr 4, 2007 | 09:54 AM
C_Rules's Avatar
i have one for sale. pm me if my current buyer decides he doesn't want it I'll sell it to you.
