LT1 Vette vs. LT1 Fbody
low 14s is the normal stock time for a car with no issues.
Vette IRS's aren't like Ford IRS's. Don't ask me why Ford didn't get smart and copy the Vette design and geometry for the cobra's. A solid axle is nice when the antisquat geometry is optimized, But Vette's put it down pretty good stock. You'll see a 4 link section underneath and the brackets were changed several times to change the anti squat geometry on the c4 vette's over the years. It's not until the high tens that things start breaking. Even then it's not the axles, but the fact that the front of the Dana 44 housing is supported by an arm that runs to the tranny and the whole car twists enough that it breaks the housing at that mounting point. Roll cage work that supports the housing better helps.
im not sure if the do or they dont, but stock vs stock if the vette does hook better its due to the fatter tires id imagine
97 was the first year of the LS1. It didn't arrive in the Fbody until 98. Gm have always done that kind of thing.
The LT5 you speak of is in a Vette known as the ZR1. I am not sure exactly what years they made it, but they are pretty rare.
Another engine that made its way into the Vette during the early to mid 90's was the LT4.
I wish they had put more LT4's in fbody, except just for a select few. Production expenses stopped that from happening among other things, but that would have been sweet.
The ZR-1 had the LT-5 from 1990 (when it came out) to 1995 when it was last produced. From '90 to '92 the LT-5 was rated at 375 horse, and from '93 to '95 it was rated at 405 horse.
The LT1 came in the Vette in '92, one year before it debuts in the Camaro/Trans Am. In 1996, the LT-4 was an option for the Corvette with the exception of the '96 Grand Sport. All Grand Sport's came factory with an LT-4 along with other performance enhancements.
All 1996 Corvettes equiped with a manual transmisson came with the LT4; the A4 cars came with LT1s. GS's are basically a cosmetic package with bigger rear tires but since they were a limited edition that looks cool, they go for a lot more money than a similarly equiped 96 M6 car.
Mike
There are some things that are budget killers, make sure that the interior and weather stripping is in great shape. You can easily spend a grand on reupholstering the seats and almost the same on weather strip. I won't even mention the "corvette tax" on body work and paint.
However, they handle great and 150mph is anti-climatic in a well maintained C4. If your into driving the quarter mile or into dynoracing stick with the F-Body. For some reason corvettes seem to dyno lower than there quarter mile times suggest and the LSX is a monster when modded. If your planning on performing a LSX implant on a C4 be forewarned its not as easy as it is in the F-bodies.
Good luck!
Mike
I guess my car was a ringer
13.9@100 1.97 60ft temp tags, absolutly stock 40k miles
13.6@102.5mph 2 weeks later cold air+underdrive pulley -cars auto w/ 2.73s
12.95@105.9mph a year later nitto drs,2800stall,exhaust,stock manifolds still, 1.6 RRs
ok sorry about that. its just that people get killed for asking something like that on a new thread. look at the sticky befor the moderators get you. and no, stock for stock, LS1's will beat an LT1 any day
