for those of you running SLP CAI help needed
Old Apr 4, 2007 | 10:38 AM
qcworm's Avatar
Default for those of you running SLP CAI help needed
how exactly does the air filters and the plastic plate install, is the clamps above or below the plastic, i pic would help me out alot, i am not sure exactly how this thing is supposed to install. correctly
Old Apr 4, 2007 | 01:53 PM
Jared 3870's Avatar
Put the plastic on, put the filters on, put into car.
The plastic block off panel should be above the filters. Crude image below.
------- <-- Plastic
\ / \ / <-- Filters
Old Apr 4, 2007 | 03:04 PM
7901 WS6's Avatar
I will try to get some pics for you later 2nite. But basically, Plate installs first, you may need to move the flat electrical box(dont know what it is off hand) thats down there to another location. Snap the plate in, Slip the CAI in, crawl under neath and remove splash gaurd under the front bumper, and slip on the filters. Make sure they are placed in the correct angle. DONT tighten them down yet until you make sure both hang in a nice setting where the clamps can easily be tighten down. so you can get the socket over them and snug them up.
Old Apr 5, 2007 | 06:17 AM
qcworm's Avatar
my plate has no snaps......it is flat on both sides, and the cai does not go below the car far enough for it to lay flat when you out tha filters on, it is brand new from slp but does not fit very good at all
