Serious LT1 Opti issues...
I recently disassembled my 5 month (2 month running) old Summit Opti-Spark, to discover the entire inside of the Opti was burned up, possibly causing a horrible misfire with any RPM over 2,500. I spoke to Summit and they shipped me a new Opti unit, and I shipped my old one back to them.
Tonight @ 9:30pm I finished installing the new Summit Opti correctly, the cam & the crank have not moved since I removed the old unit. So I bolted the Opti in exactly the same way I took the old one out so it can only go on one way into the cam assembly. I bolted the water pump back on, reconnected everything, filled the car up with some anti-freeze. Once I double checked that I had all the connections surrounding the Opti securely connected, I mounted the intake elbow, and fired up the car. The car started up instantly and idled like a champ. I let the car run for about 5 minutes, threw a couple of very smooth & very crisp revs, and shut the car off. I went to go wash my hands and come back to the car to move it off the lift, and then it no longer started!
How could the car run for 5 minutes and then just not start again? I checked for spark between the spark plugs & the wire and I saw nothing, i tried it about 3 times. I checked for spark from the MSD blaster coil & it was good. I disconnected & reconnected every connection on the front of my motor and everything seemed visually fine. I checked & rechecked for the following 2 hours without any success. It was getting late & I didn't have any spare spark plugs to change out. But tomorrow I'm going to run new wires & spark plugs just in case.
Any ideas? Can anyone give me any run-downs or a check list? Does anyone want to come up and look at the car?
After I change the spark plugs & wires, and if it doesn't start up, I'm pulling the Opti off and dissembling it.
. Hopefully my problem might help you.
