96 Motor in a 94 Z28?
Old Apr 5, 2007 | 11:09 AM
94Z28man's Avatar
Default 96 Motor in a 94 Z28?
I have a 94 camaro z28 M6. The motor blew in it and i want to replace it with a 96 motor i found for 300 with 60k miles. Will this work? Will the 94 Opti fit on the 96? Wiring harnesses the same?
Old Apr 5, 2007 | 02:28 PM
LT1's Avatar
LT1
did the 96 LT1 come with the opti? Only thing thats different is the Optispark drive mechanism. (someone correct me if im wrong)
Old Apr 5, 2007 | 02:29 PM
01z's Avatar
01z
my 96 had it. i would think you could just swap it but im not 100 percent sure
Old Apr 5, 2007 | 09:08 PM
jd783's Avatar
yes itll work just use the 94harness and change any sensor the have a different plug if there are any that are diff.i believe all the opti's have the same plug 93-97
Old Apr 8, 2007 | 06:36 PM
94Z28man's Avatar
Okay, thanks guys, I thought it would work but wasnt sure if there was anything specific i would have to look for.
Old Apr 8, 2007 | 06:37 PM
94Z28man's Avatar
Thanks guys, I thought it would work, but wasnt sure if there was anything specific I would have to look out for.
