New dyno #'s with LE2 heads
Old Apr 6, 2007 | 08:01 PM
speed_demon24's Avatar
Default New dyno #'s with LE2 heads
First off this is on the stock 99K mile bottom end, stock waterpump, and heavy 17x11's with 315's with 26psi in the tires so its not a dyno queen. I'm still having the problem at 5800 RPM's. I'm starting to think its ignition related, any ideas? Other than that the car ran great on the dyno, the baseline was 391rwhp so I gained 14rwhp. I'm going to the track tomarrow so keep an eye out for that thread with track #'s. Anyway here's the graph.
http://i86.photobucket.com/albums/k1...24/LE2dyno.jpg
30rwhp gain with the heads. I wonder what it'll put down once I fix the topend problem.
Here's video of a few runs.
http://s86.photobucket.com/albums/k1...rrent=dyno.flv
Old Apr 6, 2007 | 08:06 PM
travie319's Avatar
looks like it's running out of head......
good numbers
Old Apr 6, 2007 | 08:23 PM
cruzin94's Avatar
good numbers did u use the le2 cam also ....i hope i can get that out of mine when i get it done
Old Apr 6, 2007 | 08:26 PM
It's a custom cam I got from Bret before I got the LE2 heads, its between an LE1 and LE2 cam in size.
Old Apr 6, 2007 | 11:52 PM
sworaz's Avatar
Nice numbers! Can't wait to get mine tuned and dyno'd on the 16th!
Old Apr 7, 2007 | 02:53 AM
DroppedM6Z's Avatar
Looks like you need a better tune.....But nice numbers
Old Apr 7, 2007 | 10:00 AM
BlackScreaminMachine's Avatar
Internet Mechanic
good #'s but get the tune adjust for that dip at the end of curve so its consistant
Old Apr 7, 2007 | 10:36 AM
It's not the tune, its something mechanical...
Old Apr 7, 2007 | 01:26 PM
DroppedM6Z's Avatar
Well your Tq curve is worst than stock tunes.....I wouldnt be dynoing if it was mechanical, but thats just me
Old Apr 7, 2007 | 01:33 PM
And how exactly is the torque curve worse than a stock tune? You might want to get a clue before you start spewing random BS. And I guess I was sopposed to majically know that I had a problem that caused a power dropoff uptop without getting it on the dyno too huh?
Old Apr 7, 2007 | 02:00 PM
DroppedM6Z's Avatar
Well for starters here's a car dyno'd with a stock tune and the Tq curve seems to hold alittle more of a line. I am not trying to be rude or **** you off, just simply saying i wouldnt be happy with the tune. Your number should start off close very close to your peak and them slowly fall, instead your tq curve is flat then jumps to make a peak number and falls again.
Old Apr 7, 2007 | 02:04 PM
vanilla89's Avatar
those are some good #'s,but it look's like you got a bad opti or the rockers are to thght.
Old Apr 7, 2007 | 09:42 PM
Aftermarket cams don't stay flat, once they start scavenging the torque skyrockets.... It's not the tune, thats how the cams powerband is.
Old Apr 7, 2007 | 09:43 PM
1/16th preload, and there is no miss, and the MAF reading goes crazy at 5800+ so that leads me to think it is valve float.
Old Apr 7, 2007 | 11:28 PM
DroppedM6Z's Avatar
wow, thats funny seeing how this 234/242 pulled....it sure jumps....lol.
Old Apr 7, 2007 | 11:46 PM
Nice #'s, is that your car? It looks like that dyno graph as the asme problem as mine just at 6000 instead of 5800. BTW my cam is abot 10 degrees smaller than an 847. That torque does make me jealous though, thats on a 355 right?
Old Apr 7, 2007 | 11:52 PM
DroppedM6Z's Avatar
No, it's a friends 355 that i based my build on, Lol sorry i tried to post my graph and link wont work. I made 417/410 and the graph looks about the same.
Old Apr 7, 2007 | 11:54 PM
Yes thats the First pull on the 355.....ending numbers were 418/410
Get some track #'s now. I thought the 847 was supposed to have no torque . I guess you proved that myth wrong, you have 40rwtq on me
Old Apr 7, 2007 | 11:57 PM
DroppedM6Z's Avatar
The 847 is a good cam for a shelf cam, Im wanting a custom grind when i go 383
The cars went 12.2 @ 117 like it looks in the sig pic. I have yet to mount the ET drags
Old Apr 8, 2007 | 12:10 AM
I just got back from the track, I went 12.09@118.11 in full street trim bogging to a 1.93 60'. I only got 2 runs in, it was PACKED.... I was hoping for 11's, but I can't complain with a 12.0 right out of the box.
